Satin sheet I cannot calibrate I have hit the -2.0 limit..
[Resuelto] Satin sheet I cannot calibrate I have hit the -2.0 limit..
raymate
(@raymate)
Just got my Satin sheet but I cant lower the print head low enough I have gaps in the calibration print.
Im at -2.0, anyway to make this now lower?
My smooth sheet is -1.840 and it seem the satin sheet is a tad thinner.
Anyone else hit this -2.0 limit?
Best Answer by Technical Ted:
On my Mk3S+ you can raise the  Super PINDA sensor a little bit and that will lower all Z settings. You'll have to re-calibrate all your stored sheets though. When I built my kit a few weeks ago they instruct to set the initial height of the Pinda with the thickness of one of the small zip ties they send you. Adjust from there if needed.
Ted
Prusa Mini+ (Ordered Dec 19,2020 - Arrived Feb 21,2021) stated clicking Mar 2nd / MP Select Mini V2
Respondido : 16/04/2021 8:21 pm
tdashadow
(@tdashadow)
RE: Satin sheet I cannot calibrate I have hit the -2.0 limit..
I have same issue with the textured PEI. Smooth is at -1.903
04/21 Mini+ Bondtech Heatsink and Extruder
Respondido : 16/04/2021 8:38 pm
raymate
(@raymate)
@tdashadow
Oh thats not good, lets hope Prusa can change the firmware let it go to -3
Respondido : 16/04/2021 8:41 pm
Technical Ted
(@technical-ted)
Ted
Respondido : 16/04/2021 9:01 pm
raymate
(@raymate)
Posted by: @technical-ted
Ted
Interesting, I set mine with a credit card, maybe thats to think
Respondido : 16/04/2021 9:12 pm
tdashadow
(@tdashadow)
I got prebuilt Mini+ and there was nothing in the manual, but I can raise the SuperPINDA. thanks
Respondido : 16/04/2021 9:19 pm
raymate
(@raymate)
Ted
You are spot on I just did chat with support they said use zip ties, credit card was a bit too thin 🙂
Respondido : 16/04/2021 9:21 pm
The old PINDA was supposed to be about 0.8-1mm from the steel sheet, the SPINDA needs 1.5 mm. I don't think what's in the assembly instruction is correct anymore. A zip tie is about 0.8 mm, and unless you use an Amex Platinum, I don't think a standard CC is thick enough.
I created this little gadget, in collaboration with @with_maltodextrin, to get the distance right: https://www.prusaprinters.org/prints/57192. Just used it this afternoon when I upgraded one of my machines to Mk3S+.
Respondido : 17/04/2021 12:52 am
1 les gusta
raymate
(@raymate)
@fuchsr
Nice I printed said calibration tool, used it and now I have it working as it should. Its for sure not a credit card width.
Respondido : 17/04/2021 4:20 pm
Eirlink
(@eirlink)
@fuchsr
im getting a 404 error when i click the link? any chance you can repost?
Respondido : 18/04/2021 7:43 pm
Try this.
https://www.prusaprinters.org/prints/57192-spinda-height-adjustment-tool-mounts-into-3030-ext
Respondido : 18/04/2021 7:51 pm
1 les gusta
@eirlink
Here is another fine PINDA/SPINDA/MINDA calibration tool  https://www.prusaprinters.org/prints/57049-lehre-fur-pindaspinda suitable for the Mini and the MKx series.
Respondido : 18/04/2021 7:56 pm
1 les gusta
Eirlink
(@eirlink)
@karl-herbert
thank Karl
Respondido : 18/04/2021 8:00 pm
raymate
(@raymate)
@fuchsr
I used this one and worked a treat, I love how I can leave it attached to the mini 🙂
Respondido : 18/04/2021 8:50 pm
