Rough texture at curve printing
Antonio de la Fuente
(@antonio-de-la-fuente)
I am using firmware version 4.2.1-final+2072, the printer was delivered in August and a part from an under extrusion problem, is being printing fine. Just recently start doing rough texture printing in curves, I've attached a picture to show it. I've reset the prusa slicer to a new printer in case I've kept some changes in the slicer print settings after experimenting with printings and also using octoprint, I've disable most of the plugs that I have installed, but I still get the same results. I am new to 3D printing and I don't know where to start looking at. It seems to me that is not a hardware problem, when printing these rough areas the machine stops and starts printing again as if it was following some gcode, doing it on purpose.
Thank you in advance, and please let me know if you require more information.
Regards,
Antonio.
Postato : 14/10/2020 12:22 pm
