RE: Prusa mini users prints gallery ?
Direct comparison. One is from the MK3s the other is from the mini. Same filament, both sliced in PrusaSlicer with the same parameters and auto generated support.
It is a difficult model which at this smaller size causes all my printers a bit of trouble but the Prusa's do the best job. On the whole, they are pretty similar. If I had to choose though, I would choose the one on the right.
The Mk3s in the one on the left and the mini is on the right.
Can you link to the STL or save & zip the 3MF project file for this piece? Looks like an interesting challenge.
@bobstro
Well even at this size which is around 9cm diameter, it takes around seven hours to print as there is a fair bit of support required (The last full size one I printed took over five days 🙁 ). I have just posted this on thingiverse as you showed a bit of interest. However, it is a part of a larger model which I sell as a limited edition item so I can't make the model public domain as I usually do. It is here if you want it and if you manage to find a better profile for printing this I'd be happy to hear of it 🙂
https://www.thingiverse.com/thing:4174988
Thanks for sharing the part. I like to experiment with printing challenges. This one definitely pushes the envelope!
