Prusa Mini: Connect a camera that can also control the printer?
I noticed that Mintion are selling a camera that connects to the USB port, which allowing remote view of the print, remote control, and also take a video of the print process.
They claime that Prusa Mini is supported, but they don;t know if the Mini (without the plus) is supported.
I think that is the Mini+ is supported, so should be the Mini, because the difference is not related to the main board and firmware.
I sent a question about that to Mintion. They replied fast withy: we don't know, "Do you have a Camera and use it on the printer, "Use the custom type in the model"?"
I have a few questions:
1- If it works on the Mini+, its should work on the Mini, right?
2- Did anyone try it? Any recommendation?
3- Any other stand alone solutions like that? (unlike RPI+Octoprint for example), because the beagle brings also wifi connection
RE: Prusa Mini: Connect a camera that can also control the printer?
I have the strong impression that this camera only works with printers that are equipped with an 8-bit motherboard.
There is a mini in their list, but that is not a printer but the SKR mini board.
That is an update controller for the Creality Ender 3 printer series.
I therefore think that this camera will not work in combination with a Prus mini (+) printer.
How do you know it is the SKR board?
The Prusa Mini has the buddy, and only buddy, right?
I will ask them directly (they answered fast !), yet I find it strange that a modern product will have such a limitation.
As you can see in the picture, only prusa I3 MK3s+ printer is compatible with their camera.
If it were the case that the Prusa mini (+) was compatible, that would have been mentioned there as well.
So I'm curious what their answer will be.
OK. in that case it should also work with the mini.
The mini+ printer has the same board as used in the mini.
