Printing artifact help? Vertical lines
lnjustin
(@lnjustin)
I’m getting some artifacts in printing. See pic. Lines where I guess the printing head repeatedly changes direction maybe? Any way to prevent?
Best Answer by Walter Layher:
You find this in Print Settings > Layers and perimeters, look where it says "Aligned" and change that setting to "Random".
Veröffentlicht : 30/05/2023 1:39 pm
Walter Layher
(@walter-layher)
Did you print with "variable layer height"? If so, try to turn that off to get a more uniform result.
Ah, sorry, I see what you mean now. That is the seam from the layer change. You can choose to distribute the layer changes so that they do not appear as a straight line.
Veröffentlicht : 30/05/2023 1:45 pm
Walter Layher
(@walter-layher)
RE: Printing artifact help? Vertical lines
Veröffentlicht : 30/05/2023 1:54 pm
lnjustin
(@lnjustin)
Thanks! Wonder why anyone would ever want the layer changes aligned, and why that’s the default setting…
Veröffentlicht : 30/05/2023 1:56 pm
Walter Layher
(@walter-layher)
Every part is different and some parts have a side that is always at the back and no one will ever look at it. Also if you put the seam in a corner (at the back) it will be less visible. You can also paint on the seams where you would want them to be.
Veröffentlicht : 30/05/2023 1:59 pm
lnjustin
(@lnjustin)
So if I change this to random will it be a bunch of random bumps on the part? Like, the bumps are inevitable and it’s just a matter of where to put them? Or does making them random mean they won’t be accumulate into a raised bump on the surface?
Veröffentlicht : 30/05/2023 2:02 pm
Walter Layher
(@walter-layher)
You can tune the size of the bumps e.g. with you retraction setting to make them less prominent.
Veröffentlicht : 30/05/2023 2:05 pm
Walter Layher
(@walter-layher)
Best read this: https://the3dprinterbee.com/how-to-hide-avoid-z-seam-cura-prusaslicer/
Veröffentlicht : 30/05/2023 2:08 pm
