Print object with PLA Crystal clear ?
ymasur
(@ymasur)
I have tried to print with the "PLA Crystal clear" with my Mini. But after a short time, the extruder doesn't make any plastic out. I have tested to print the piece first at 215°C, then more and more until 240°C.
Each try, I must dismount the extruder part, extract the remaining filament with a pliers, remove the grind... Painful. The same projetc printed with white filament goes well.
An idea?
Dieses Thema wurde geändert Vor 5 years 3 mal von ymasur
Veröffentlicht : 25/05/2021 1:21 pm
RE: Print object with PLA Crystal clear ?
White has more pigment than any other colour, clear has none.  The white is inherently more crush-resistant, so:
Try unscrewing the idler tensioner a little. It should only just bite the filament and not crush.  Also clean your print bed thoroughly, with soap and hot water, not whatever it is that's causing those scratches.
Veröffentlicht : 25/05/2021 2:05 pm
