Persistent Filament Gear Slipping on Prusa Mini – Underextrusion and Full Stops
Noedel
(@noedel)
Hi all,
I’ve been running into persistent extrusion issues on my 5-year-old Prusa Mini and I’m hoping someone here might have additional ideas.
The problem: The filament drive gear keeps slipping and digging into the filament, which causes underextrusion and sometimes a complete stop of extrusion.
What I’ve tried so far:
  • Ordered 2 new gears, but they arrived in terrible condition (burrs, damaged teeth). After some cleanup, I managed ~20 hours of good printing before the same issue reappeared.
  • Replaced the Hotend PTFE tube once (a while ago).
  • Mostly using the 0.4 mm nozzle, occasionally the 0.25 mm since last year.
  • Tried multiple filaments (both old and new).
  • Performed cold pulls about 5 times.
  • Adjusted nozzle temperature up and down.
  • Adjusted the tension screw (both tighter and looser).
  • Cleaned the filament feed tube.
Support experience: I contacted support multiple times by email (24/7 chat seems broken). They said the gears “look fine” (though my mechanical engineering professor disagreed after inspection) and suggested fixes I had already tried. Essentially, I’m stuck without a working resolution.
My questions:
  • Is there anything else I can try to troubleshoot or fix this?
  • Has anyone else run into this kind of gear quality issue?
  • How do I get support to recognize that the part they supplied was defective?
At this point I’m looking for any last-ditch advice before the printer becomes unusable.
Thanks in advance!
Posted : 20/09/2025 10:56 am
_KaszpiR_
(@_kaszpir_)
RE: Persistent Filament Gear Slipping on Prusa Mini – Underextrusion and Full Stops
I would double check the nozzle temperatures if they are in range. Recently someone had to replace the thermistor because it was reporting much higher temperatures than they actually were ( say it reported 230C while in fact it was something like 210C).
Second thing is to check that short PTFE tube if it is not melted and if it is properly compressed ao that filament does not get stuck because it is not in a melting zone.
Finally, some people switched to Bondtech https://www.bondtech.se/product/ifs-extruder-for-prusa-mini/
Posted : 21/09/2025 7:43 am
Noedel
(@noedel)
Thanks for the suggestions!
How would I be able to properly check if the thermistor is reporting the wrong temperature? Is there a way to measure this externally to compare it with the printer’s reading? I haven't had any previous issues with this.
As for the short PTFE tube, I can replace it, but I’ve always found it very difficult to remove without damaging it – usually I end up needing to replace it once it’s out. Do you have any tips on getting it out safely, or on how to check if it’s seated/compressed properly without fully removing it?
The Bondtech extruder does look like a solid option, but I’d prefer to save the money and get the stock extruder working reliably first if possible.
Posted : 21/09/2025 11:04 am
_KaszpiR_
(@_kaszpir_)
At least check its cabling first, I had some thermal runaway errors due to thermistor cables being too squeezed and reporting lower temperature in comparison to reality ( which is a bit different to your issue but cables can cause various problems especially if they are squeezed and the whole system moves causing extra cable strains and relaxations all the time).
Temperature checks could be done with something simple as food cooking thermometer, or more advanced such as multimeter with a thermocouple. But it may be just cheaper to buy a new thermistor in the first place.
I think the easiest test is with clean PETG ( or non matte), print it slow and thus the output PETG should be glossy at around 230C, if the temperature is too low or the extrusion speed is too high then it will get matte because it did not have enough time/ temperature to melt properly. You can do something like a first layer calibration with custom temperatures going down with a constant print speed.
Short PTFE tube should be possible to remove without an issue at all. If you have problems removing it with a pair of tweezers then I think that may be a sign of other issues - it may mean the assembly is incorrect or you suffer from the heat creeping from the heat block up through heatbreak and not being properly cooled by the radiator and the fan - this is a know issue with the mini and sometimes it requires proper placing of the heatbreak and reapplying the thermal paste between heatbreak and the radiator. I would also check if the three screws in the radiator are properly locking the heatbreak in its place. Some people replace the heatbreak with something better ior even replace the whole hotend to also mitigate other issues ( such as hardened nozzle in aluminium ends in damaging thread in aluminium). I switched to Slice Engineering kit for Prusa Mini and havent got any issues whatsoever.
Bondtech extruder replacement may not be enough, you may just suffer from other issues, so I believe proper melting and cooling ( hotend and a heatbreak) is more important - I would focus on that, and maybe plan extruder replacement later on.
This post was modified 1 day ago 4 times by _KaszpiR_
Posted : 21/09/2025 4:17 pm
_KaszpiR_
(@_kaszpir_)
One more thing. Notice that the short PTFE tube has specific angles ar the ends (120 degrees), which helps in minimizing the gap between the tube and the heatbreak https://help.prusa3d.com/guide/how-to-trim-ptfe-tube-original-prusa-printers_22424#133076
Posted : 21/09/2025 4:34 pm
Noedel
(@noedel)
I tried removing the PTFE tube and it seems fine, and the thermistor checks out as well. That makes me think heat creep could indeed be part of the issue. The only problem is that the 3 screws on the hotend radiator are really stuck. I can’t seem to loosen them at all to check the heatbreak or reapply thermal paste.
In the meantime, I decided to give printing with the old drive gear another try and (knock on wood) it’s actually running fine again for now.
Posted : 22/09/2025 9:43 am
Noedel
(@noedel)
Still those new gears I ordered are not up to the standard you would expect from a company like Prusa3d.
Posted : 22/09/2025 10:14 am
Noedel
(@noedel)
Only real issue I'm seeing now is an uneven side surface which wasn't there before... (it does look a bit worse on the image)
Posted : 22/09/2025 2:22 pm
