New to Forum
stephenfaplatt
(@stephenfaplatt)
New to Forum
Hi
I am new to the forum and about to buy a Original Prusa i3 MK3S kit, will it print with ABS? if so what is the best brand to buy?
Respondido : 27/05/2020 7:06 pm
Matteo Cristini
(@matteo-cristini)
RE: New to Forum
Hi and welcome to the forum! This is the prusa Mini forum though 😉
Yes, the MK3 can print abs just fine, though I can't really recommend any brands since I've never tried it.
Respondido : 27/05/2020 7:29 pm
kenatno10
(@kenatno10)
RE: New to Forum
Hi ,
I am also just starting.
I found asa good , struggled with pla on its standard settings.
Smooth sheet good with asa .
Found experimenting with different settings in the prusa slicer helped improved prints.
Make sure you tension your belts enough to begin with , as the manual although good can be easy to make mistake . Needs to be abit like a guitar string twang . There is a belt tension test when its up and running. Especially on the extruder belt.
Worth using a level on the smooth rods to check horizontal position on the threaded rods before set up.
Also on heated bed to check machine is level.
Respondido : 27/05/2020 8:39 pm
