*NEW* 4.3.0-RC2 Firmware for Original Prusa MINI/MINI+ is out
Pagina 3 / 3
Utenti
RE: *NEW* 4.3.0-RC2 Firmware for Original Prusa MINI/MINI+ is out
I confirmed that my issue as a bad power supply.
Postato : 26/01/2021 11:13 am
Zoltan
(@zoltan)
Utenti Moderator
@technogeeky
during the print the only Change filament command makes a sense, does it work with Octoprint?
Nevertheless I cannot imagine to LoadúUnload filament remotely, unless you do not have any automated workbench.
M600 works with MINI perfectly.
Postato : 26/01/2021 2:19 pm
ideastudios
(@ideastudios)
@zoltan
M600 does work just fine.
The various OctoPrint plugins which help you load/unload filament and/or track the spools don't seem to do anything with load/unload. This could just be a configuration thing.
If you're connected via OctoPrint, on the Tune menu there is a 'Change Filament' option but it's always disabled and grayed out.
To load/unload with the current stock firmware, you have to disconnect OctoPrint and do load/unload, then re-connect OctoPrint. It's only a tiny bit of hassle.
I would love it if instead of OctoPrint "taking over" the interface, the interface worked like it does with USB drive prints entirely except maybe a small overlay icon letting you know the print is coming from OctoPrint.
Postato : 26/01/2021 2:48 pm
@zoltan
I can confirm that the M600 manual filament change owith octoprint works fine on the Mini with FW 4.2.0. I have not tested the 4.3.0 RC2 in this regard.
Postato : 26/01/2021 4:12 pm
M600 FW 4.2.0 with octoprint:
systeminformation:
Description: Raspbian GNU/Linux 10 (buster)
Kernel: 5.4.83-v7+
Octoprint: 1.4.2
octopi: 0.17.0
Postato : 26/01/2021 4:15 pm
keithywhites
(@keithywhites)
how do i compile this firmware for my mini? do i have to use vs code as its 32 bit? is there any guides to do this?
Postato : 26/01/2021 10:28 pm
Lupin
(@lupin)
Did you read the README.md? Your question sounds like you did not.
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/master/README.md
Postato : 27/01/2021 7:20 am
Zoltan
(@zoltan)
Utenti Moderator
@keithywhites
I would recomend any changes to be done by people rather experienced in C/C++ programming and with knowledge of STM32 and FREERTOS.
You do not have to use vs code you can use any other appropriate editor to change the code and  there is a python command (see readme on github) you can run from local directory for local build of  .bbf file. But you will not be able to flash it without broken appendix which leads to warranty loss..
Postato : 27/01/2021 11:08 am
DaddyBoomalati
(@daddyboomalati)
I have to say the steel sheet profiles are the greatest thing since sliced bread.
Thanks for your hard work!
Questo post è stato modificato 4 years fa da DaddyBoomalati
Thanks,
Dave Smith
Postato : 28/01/2021 2:19 am
Pagina 3 / 3
