Mini R2 Update
bradmcgonigle
(@bradmcgonigle)
Mini R2 Update
Looks like there is an update for a few of the Mini's parts. https://github.com/prusa3d/Original-Prusa-MINI/releases
MINI-fan-spacer
MINI-fan-spacer-clip
  • new mounting method of the extruder cables
MINI-minda-holder
  • more robust part held in place by 2 screws
MINI-x-carriage
  • belt slots adjusted
MINI-x-end
  • opening holes for screws holding part on the smooth rods
MINI-knob
  • increased height of the knob
  • deeper hole for encoder shaft
MINI-z-bottom
  • adjusted screws holding Buddy board in place
  • reinforced slots for z-bottom-cover
  • opening for power connector adjusted for better printing
  • better aligment of USB connectors holes
  • slot for nut holding cover in place adjusted to eliminate nut falling from the slot
MINI-z-bottom-cover
  • wider protrusion for better cable management
MINI-display-box
  • larger hole for encoder
Napsal : 23/01/2020 6:29 pm
jaydubblazer
(@jaydubblazer)
RE: Mini R2 Update
Wow I can almost rebuild my printer
JayDub
Weened on MK3's at work, FrakenMini and MKs at home.
Napsal : 24/01/2020 1:42 am
1 lidem se líbí
Strankler
(@strankler)
RE: Mini R2 Update
Did anyone already installed the R2 parts? Especially for the MINDA probe?
Is there a "How-to install" manual somewhere? I didn't find anything on https://manual.prusa3d.com.
There are pictures in the blog post https://blog.prusaprinters.org/2019-recap-plans-for-2020-and-original-prusa-mini-update/ which shows how it shall look like, when installed, but there are further screws and nuts to be mounted, and I'd like to know which sizes I have to use.
Napsal : 25/01/2020 10:40 am
PengLord
(@penglord)
RE: Mini R2 Update
@strankler
There are no extra screws required for the probe mount, three screws hold the old part and the new part.
Two go through the mount and fan and thread into the heat sink, one clamps the probe.
The only part that requires a new screw is the fan spacer/cable clamp, I grabbed the correct screw from the spare bag, no nut is required.
Napsal : 25/01/2020 12:07 pm
Crawlerin
(@crawlerin)
RE: Mini R2 Update
@strankler
Same, while changing parts is probably not rocket science, I'd also appreciate some list of additional parts like screws and nuts, and how to replace it properly. Quite possibly full assembly manual is used internally and not yet in state of being published.
PengLord
(@penglord)
RE: Mini R2 Update
Posted by: @crawlerin
@strankler
We posted at almost the same time, the reply above your post should be helpful.
Napsal : 25/01/2020 12:09 pm
Crawlerin
(@crawlerin)
RE: Mini R2 Update
@penglord
Yeah just had the page refreshed by posting it... thanks!
Napsal : 25/01/2020 12:11 pm
PengLord
(@penglord)
RE: Mini R2 Update
Reposting an edited version for accuracy:
One goes through the mount and fan and threads into the heat sink, one goes into the X-Carriage, one clamps the probe.
I still need to print and replace the X-carriage and display box. So far the only part that requires a new screw is the fan spacer and clip, I grabbed the correct screw from the spare bag, no nut is required.
Napsal : 25/01/2020 12:42 pm
Strankler
(@strankler)
RE: Mini R2 Update
Thanks guys.
This is truly helpful for everyone, who will deal with that.
I manly was wondering if there is a manual, which I just didn't find.
One more thing to add in your recap: The only part that requires a new M3x20 screw is the fan spacer/cable clamp.
Napsal : 25/01/2020 1:33 pm
1 lidem se líbí
