MINI - Diagram with Labels?
brockparks
(@brockparks)
I'm new to 3d printers and Prusa, and it would be helpful if there was a diagram or cutway of the Mini that labels each part so that I could easily learn common terms and know how to reference them with others.
Some things are obvious, such as the heatbed, z and x axis, etc, but others are vague.
Is there a diagram or resource that has been shared in the community that people can reference to describe parts, so that it's a shared point of reference?
Thanks 🙂
Best Answer by jharding2185:
Found it, Link below
https://www.prusa3d.com/mini-360-viewer/
Opublikowany : 03/08/2020 1:40 pm
jharding2185
(@jharding2185)
RE: MINI - Diagram with Labels?
I've seen a blow-up of the mini on the site, from AutoCAD, cannot find it right now though...
Opublikowany : 03/08/2020 9:50 pm
jharding2185
(@jharding2185)
Opublikowany : 03/08/2020 9:56 pm
atomleef polubić
brockparks
(@brockparks)
@jharding2185
Would LOVE to see it... I'm a noob, and sometimes it's easy to forget how little we know, lol 🙂
Thanks!
Opublikowany : 03/08/2020 11:21 pm
atomleef
(@atomleef)
@jharding2185
awesome
Opublikowany : 04/08/2020 9:18 am
atomleef
(@atomleef)
@brockparks
suggest to study about hot end, heat block, heat break, nozzzle, minda,  extruder, ptfe tube(in heat block)
i am new too, firstly i confuse many part.
extruder have door that allow you to clean and observe it, try to open and familiar with it 🙂
Try watch this, problem will come to you some day(i already face once)
Opublikowany : 04/08/2020 9:29 am
brockparks
(@brockparks)
I'll check this out - tks!
Opublikowany : 04/08/2020 10:43 am
atomleef
(@atomleef)
@brockparks
try read this
https://help.prusa3d.com/en/article/layers-and-perimeters_1748
prusa slicer also have vast mode if you want to print with no seam try search it
ps. try many tolerance print, you will learn about about 45 degree print and bridge(i print house model while do not know about  bridge and that make my model suffering with woo many support)
https://all3dp.com/2/3d-printer-tolerance-test-and-improve-your-3d-printer-s-tolerances/
Opublikowany : 05/08/2020 3:36 am
brockparks
(@brockparks)
@jharding2185
Incredible resource! Though I'm not British, I'm a little gobsmacked at how nice that is. Thanks for finding it!
Opublikowany : 06/08/2020 12:40 am
brockparks
(@brockparks)
@atomleef
I watched this video and after I fixed my jam - the filament was caught in the extruder and I had to take it apart - I find that my prints are drifting, as his first 3 prints did with the benchy boat. I will make adjustments to the Z axis height, but hope to not have to open up the hotend, lol.
Thanks for the video link! I will update as I have progress...
Opublikowany : 07/08/2020 10:46 am
brockparks
(@brockparks)
Also found this glossary of the MINI, which is basic, but a simple labelled diagram for beginners like me:
https://www.help.prusa3d.com/en/article/glossary-mini_125081
Opublikowany : 09/08/2020 12:08 pm
atomleef polubić
atomleef
(@atomleef)
awesome thanks for sharing
Opublikowany : 10/08/2020 6:56 am
