Looking for the default contents of USB stick
P.O.
 P.O.
(@p-o)
Hello all,
I have a Mini on the way which should arrive in the coming days. I bought it used and it will not come with the stock USB stick.
Therefore I am looking for the default contents of the drive in order to be able to do the first few test prints with the pre-sliced gcode.
Also, any information about setting the printer back to factory state to run the first-time wizard again would be appreciated (although I suppose that this should be rather simple to figure out from the menu).
Thanks !
Veröffentlicht : 07/08/2022 12:17 pm
Razor
(@razor)
RE: Looking for the default contents of USB stick
Check your private messages for a link.
Mini+MK3S+XL 5 Tool
Veröffentlicht : 07/08/2022 1:36 pm
P.O.
 P.O.
(@p-o)
Hello !
Well this was fast, thank you so much for chiming in 🙂 The machine I am getting is a regular Mini (not +) but since only the probe is different I can only assume that the sliced examples are exactly the same. I'll report back on all this once I get the unit in about a week or so.
Thanks again !
Veröffentlicht : 07/08/2022 1:59 pm
Razor
(@razor)
Happened to be in the forums reading through some things and came across your post. 😁 Can't help you on what all the differences are, but I believe you are correct. Hopefully someone with more knowledge than us will be able to chime in. 😉
Good luck with your purchase. Having owned a FlashForge Adventure 3 I was about ready to give up the hobby because nothing worked right. I can't believe the improvement the Mini+ offered right out of the box. Night and day difference. This little Mini made me a Pursa customer for life.
Mini+MK3S+XL 5 Tool
Veröffentlicht : 08/08/2022 11:59 am
P.O.
 P.O.
(@p-o)
Excellent, that's great to hear ! I went the other route myself - starting out with the cheapest, nearly falling apart printer I could possibly find locally and fixing it up to the best of my abilities. Now time to move to the real deal 🙂
(couldn't reply to your PM probably because my account is too recent. Thank you for the files, I'll report back once tested).
Veröffentlicht : 08/08/2022 6:23 pm
P.O.
 P.O.
(@p-o)
Alright, "Nut_150um_MINI_PLA_1h32m.gcode" is about halfway printed by now, so I can confirm that the files were exactly what I was after 🙂
Veröffentlicht : 12/08/2022 5:58 am
Razor
(@razor)
Glad to hear. Best of luck, and catch you around soon.
Mini+MK3S+XL 5 Tool
Veröffentlicht : 13/08/2022 2:57 am
Steven Machado
(@steven-machado)
Im also looking for an image of this stick.. my other was formatted by one of the kids and I'd like to get it back
Veröffentlicht : 30/12/2022 5:59 pm
https://www.printables.com/@PrusaResearch/collections/9934
Veröffentlicht : 30/12/2022 11:25 pm
LCARS
(@lcars)
Mitglied
I also just received a used Prusa Mini+ and the USB stick has been wiped clean.
The link above does not seem to work anymore. Is there anywhere else I can look for the original USB stick contents?
Thx...
Veröffentlicht : 07/02/2024 5:43 pm
Hello, they've rearranged the furniture again; go to:
https://www.printables.com/social/16-prusa-research/collections
Scroll to bottom.
Veröffentlicht : 08/02/2024 1:08 am
