How to determine nozzle is done
MAX1
 MAX1
(@max1)
I made the mistake of download temperature towers from the print area, g code version because I was too lazy to encode the temperatures in slicer.
Unfortunately for me, and a warning to you, those g code files has some modifications for the z axis before print.
what this did was it embedmy nozzle into my print bed, drawing very nice etched lines. This was a nozzle-x
how do we know that the nozzle is done?  Do we measure it with calipers? It does not look as pointy at the tip as it once did, and I noticed my zxis has shifter (probably because the nozzle itself was crushed upon itself).
have you pushed your nozzle into the bed before by accident ?  Do you replace your nozzle after such an occurrence ?
Last question: will replacing the film On any destroyed sheet give me a flat surface again - or will the film contour back to the divots.
Veröffentlicht : 03/03/2021 9:13 pm
towlerg
(@towlerg)
RE: How to determine nozzle is done
Just out of curiosity (and I'm certainly not going to try it) will stock Marlin allow gcode to move the Z height negative?
Veröffentlicht : 04/03/2021 9:27 am
Mitglied
Posted by: @max1
I only replace a nozzle if the prints are starting to have poor quality because the extrusion is getting wide from the bore increasing.
Veröffentlicht : 07/03/2021 1:19 am
