How much stringing is too much?
DrBomb
(@drbomb)
I've had a the Prusa Mini for almost a year now. I would say my experience has been very postive, sans one thing... Stringing and Oozing.
I've tried multiple things
  • Retraction changes
  • Temperature changes and temp towers. Stringing starts to dissapear around 175C, which I think could compromise the prints
  • With Prusa support's suggestion, after getting the tools, I dissasembled and reassembled the heater block and reapplied thermal grease.
The only thing I'm missing is changing the nozzle, but I live on South America and shipping to here takes a long time. Or doing extruder multiplier callibrations which also need some specific and hard to get instruments here.
Here's the current print progress:
Print with a lot of stringing
My question to the community is:
Is this too much stringing? What are your experiences with stringing on the prusa mini? I just don't know if I'm overreacting or if I'm correct to think this is not a good stringing amount. What would you suggest me to do to get this addressed?
Thanks for reading!
Napsal : 24/11/2021 4:27 pm
sandysasmita
(@sandysasmita)
RE: How much stringing is too much?
Did you dried your filament? You can try to change the retraction length to 2mm. And most of filament should works well at 210-215 C. I think 175C is too low.
Napsal : 24/11/2021 4:45 pm
DrBomb
(@drbomb)
Yeah, I dried my filament with those drier boxes they sell in aliexpress.
Does not seem like it improved on any way. I did try adding more and more retraction on previous attempts at reducing stringing. The current print is set to a retraction of 3.2 by the Prusa Mini presets on Prusa Slicer with the stringing seen on the picture.
Napsal : 24/11/2021 5:02 pm
sandysasmita
(@sandysasmita)
For my mini, 3.2mm only works for prusament. But for the other brand, i need to change the retraction length to 2.0mm to get a better results.
Napsal : 24/11/2021 5:09 pm
BogdanH
(@bogdanh)
Posted by: @drbomb
Does not seem like it improved on any way...
Because most of them are not capable to actually dry the filament -they are meant to keep already dry filament dry, while printing. The best filament drier is the cheapest: food dehydrator.
[Mini+] [MK3S+BEAR]
Napsal : 24/11/2021 7:52 pm
Some filament will also string more than others. I'm currently fighting some Sunlu PETG, and it has resisted all my efforts to reduce stringing with ease.
A heat gun is a valuable addition to your tool kit. A few blasts of the heat gun can save you hours of optimization. Maybe intellectually less satisfying but pragmatic.
Napsal : 25/11/2021 2:41 pm
MysDawg se líbí
MichaelMilano
(@michaelmilano)
This issue is bigger than changing a nozzle or retraction. Some filaments are just stringier than others. I'm using a certain brand right now, a local one that makes my Prusa mini look like a cheap Chinese printer. It's oozing, stringing, clogging...slipping, making my extruder work harder. I thought, initially that I'm dealing with mechanical problems until i switched to a different brand.
I don't know what filament you are using but try to buy one really good roll and print again with default settings and compare.
Napsal : 02/12/2021 4:23 pm
d0ug
 d0ug
(@d0ug)
That's about average I see on mine depending on what i'm printing. I've just learned to live with it. I just take a lighter to the parts when done, makes the strings ball up against the piece, then just rub them off or scrape them off with a fingernail.
Napsal : 04/12/2021 12:31 am
