[Risolto] Help, mesh bed levelling fails at probe point 14
Linden
(@linden)
Hi all,
I recently received my Prusa Mini printer and have been really impressed by it out of the box. Yesterday however, I tried to start a print and the mesh bed levelling consistently fails at probing point 14. Everything works as expected up until that point but it won't continue beyond point 14. I've cycled the power several times and also restored the factory defaults but the problem remains.
I've attached a video of the problem for some context, any help with this would be greatly appreciated.
Mesh bed level fail
Thanks a lot,
Linden.
Best Answer by mGoleta:
Have you tried flipping the steel sheet over to see if it changes?
Postato : 20/01/2021 12:23 am
mGoleta
(@mgoleta-2)
RE: Help, mesh bed levelling fails at probe point 14
Postato : 20/01/2021 2:17 am
Linden
(@linden)
@mgoleta-2
I hadn't but that worked a treat, thanks so much for the help!
Postato : 20/01/2021 2:39 am
mGoleta
(@mgoleta-2)
@linden
If you flip it back and it still has a problem then there is likely a defect in the sheet. Since it is new you may want to contact PRUSA customer support about a replacement.
Happy printing.
Postato : 20/01/2021 7:36 pm
