First layer temperatures lower than the other layers ones?
Muldee Things
(@muldee-things)
Hi everyone, a noob question here. Looking at the various PETG filament settings in PrusaSlicer I see that nozzle temp for the first layer is usually 10° lower than the set temperature for the other layers; even the hotbed temp is 5° lower for the first layer.
Shouldn't be the opposite? Shouldn't be the temperatures higher for the first layer?
Publié : 16/04/2020 7:28 am
xhillb61
(@xhillb61)
RE: First layer temperatures lower than the other layers ones?
No, it´s correct this way
Publié : 16/04/2020 10:04 am
Muldee Things
(@muldee-things)
@ulrike-b
Thank you for your answer. Would you mind explain why?
Thank you.
Publié : 17/04/2020 7:32 am
PETG has a tendency to stick to the nearest hottest thing. It's therefore common to have the nozzle a bit cooler and the bed a bit hotter on the 1st layer to encourage it to stick to the bed and not the nozzle.
Publié : 17/04/2020 12:28 pm
Bill Plein a aimé
