Firmware 4.0.1-FINAL for the Original Prusa MINI
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Hi guys,
this a first public stable firmware upgrade, recommended to all users.
What is new?
  • Introduction to the MINI firmware
  • Fixes and improvements in 4.0.1
  • Other important repositories
A detailed description of changes:
This is the first public release of the firmware for the printer Original Prusa MINI. This is a brand new branch of a firmware tailored for the Buddy board MINI developed by Prusa Research. Compared to the previous firmware for MK2S/MK3S, which is based on the 8-bit architecture is this firmware 32-bit and using ARM STM32F407 chipset.
The firmware is utilizing Marlin 2.0 to handle motion planning with multiple tweaks to comply with the Prusa in-house developed technologies. The user interface, WebUI and other parts of the firmware are fully developed at Prusa Research.
The board is capable of running RTOS (Real-Time OS). Therefore there are several parallel threads:
  • Marlin 2 (motion planning)
  • LCD GUI (graphic interface)
  • Networking (LAN and Wi-Fi communication)
Several printers from the initial batch were shipped with firmware 4.0.0. Users are advised to flash the newest firmware as it brings some fixes and improvements:
  • Improved homing algorithm
  • Improved dialogue for color change (M600)
  • Wizard stability
  • Filament sensor ON/OFF setting kept after a reset
Other repositories
Original Prusa MINI - https://github.com/prusa3d/Original-Prusa-MINI
Buddy-board - https://github.com/prusa3d/Buddy-board-MINI-PCB
Heatbed - https://github.com/prusa3d/Heatbed-Mini-PCB
IR sensor - https://github.com/prusa3d/MKxS-IR-sensor
Supported printers:
  • Original Prusa MINI
Download link:
prusa3d.com/drivers/
How to flash the firmware on MINI:
  1. Copy the firmware file (.bbf) onto the USB drive with FAT32 formatting
  2. Insert the flash drive in the MINI's USB port
  3. Turn the printer ON (or reset it)
  4. During the boot screen hit (press) the knob once
  5. A new screen will appear (if not, repeat the process)
  6. Confirm you want to flash the firmware
  7. Wait till the firmware is flashed and printer fully boots into the home screen
Please report any bug here:
github.com/prusa3d/Prusa-Firmware-Buddy/issues
As always, we wish you happy printing and look forward to your feedback!
Ce sujet a été modifié il y a 6 years 2 fois par Jakub Dolezal
Assembly manuals
/ Knowledge Base
Publié : 26/12/2019 10:29 am
kiteslammer
(@kiteslammer)
RE: Firmware 4.0.1-FINAL for the Original Prusa MINI
Is this update enabling networking via lan
Publié : 20/01/2020 3:15 pm
Crawlerin
(@crawlerin)
Is the 4.0.2 posted in Downloads and drivers section final? Are there more detailed patch notes available than "support for mk3s lcd encoder"?
Publié : 06/02/2020 1:52 am
Olef
 Olef
(@olef)
(cross posted from the firmware thread)
Looking at all the changes noted into 4.0.2 on Github, versus the 4.0.2 on the download page which apparently only has the change for the different encoder, I believe there has been a mistake in naming. Based on the changes listed I believe the drivers page version should be more like 4.0.1a.
It is now 52 days since the last Mini firmware, excluding the hardware change version above... 🙁
Publié : 09/02/2020 12:48 pm
