[Gelöst] Cura 5 crashes when trying to add Prusa Mini
nuggetz
(@nuggetz)
I found the prusa profiles for Cura but it seems to crash the latest version of Cura when importing the printer definition and trying to select the mini under Prusa Research. I know the software version is relatively new but wondering if anyone has experienced this and if there's a fix? Maybe someone can export their working Mini printer config and share it?
I'm using the json file from here:  https://help.prusa3d.com/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856&_ga=2.147995511.1553972471.1657410984-2085571774.1657410984
Veröffentlicht : 10/07/2022 2:25 am
nuggetz
(@nuggetz)
RE: Cura 5 crashes when trying to add Prusa Mini
Figured it out. Need to ensure that the extruder file as well as the definition and mesh files are in the correct folders.
Veröffentlicht : 10/07/2022 2:50 am
jsw
 jsw
(@jsw)
There are reports over on the Ultimaker forum that the new Cura 5 (not ready for prime time, IMAO) does indeed crash, on some platforms at least, under various circumstances.
The specific issue I reported on it was that it does not allow the use of the absolute full x-y dimensions of the build plate on the S5.  For me, if I reduced the X dimension of the object by .3mm, it would, but definitely grayed-out the object at full width.  (And yes, I do have one model that needs the full 330mm.)
Veröffentlicht : 10/07/2022 10:54 am
