Can I Use Any Isopropyl Alcohol Wipes with the Smooth PEI Sheet?
AlexLandherr
(@alexlandherr)
Regarding cleaning of the PEI sheet for PLA printing I was wondering if I can use any isopropyl alcohol wet wipes for cleaning it? Since I can't find them sold separately in the E-shop it seemed like a good question to ask.
Best Answer by bobstro:
The riddle of adhesion
You’ve probably seen some of these guidelines before and may have wondered exactly why these simple-sounding steps work. Here’s an unscientific breakdown.
  1. Isopropyl alcohol and acetone work as solvents breaking apart grease molecules. These solvents do not completely dissolve grease, but do break it down far enough that it can be removed from surfaces easily.
  2. The more concentrated the solvent, the more effective it will be at a given volume. Those little 70% isopropyl wipes do work… on a shiny new PEI sheet. They’re just not effective in dealing with larger amounts of accumulated grease. This is why 91%+ alcohol is recommended.
  3. Acetone is even more effective, breaking up oxidation on the PEI surface, but can make the PEI surface brittle and prone to cracking if over-used.
  4. The amount of grease that any solvent will effectively break down is directly proportional to the volume of solvent to grease. The more you apply, the more grease it can effectively break down. The more concentrated the solvent, the more grease a given quantity can break down.
  5. Alcohol, acetone, and any other solution you apply directly to the bed is just going to move those broken-down grease and grime molecules around. Some will be picked up by wiping with a clean towel, but some will remain on the PEI sheet.
  6. A dunk under the sink with Dawn dish soap is the most effective method of cleaning. Dish soap is a surfactant, not a solvent. It works in a fundamentally different way, bonding both grease and water molecules to wash away contaminants. The reason this is so effective is not because Dawn is “stronger”, but because there’s simply a much greater volume of Dawn and water and the grease is washed away from the PEI sheet.
  7. Windex, a wipe of finger grease, talcum powder or specialized release agents can be used to reduce adhesion when using hot, sticky materials that grip the PEI surface too firmly such as PETG. It is still a good idea to clean the PEI before a print to get an even surface, even if you will be applying a release agent for printing with sticky materials.
  8. If you are printing high-temperature materials (e.g. PETG at 260C on a 90C bed), test to make sure it will release once cool without damaging the PEI surface. You may want to use a glue stick or other release agents for these materials. Test on a sacrificial PEI surface if possible. See over adhesion notes.
A bit of trivia - The reason higher concentrations of alcohol seem to be harder to find is that isopropyl alcohol is most effective against bacteria at roughly a 71% concentration. A bit of distilled water helps slow evaporation, making the alcohol more effective. If you're looking in pharmacies, that's why 91% and higher seem to be hard to find.
Helpful answers are appreciated. I usually respond to Tweets directed at me.OS: Raspberry Pi OS & Windows 10. Programming Languages: Python & Java
Publié : 04/08/2021 2:53 pm
BogdanH
(@bogdanh)
If wipes contain IPA only (no scents, no "skin care" stuff) then I see no reason why you wouldn't use it for cleaning (any) print sheet. However, I think it's more reasonable if you buy IPA in bottle: is probably cheaper than wipes and will last you longer. There are smaller bottles (about 200-250ml) where you can spray IPA on print sheet and then wipe with paper towel or some micro-fibre cloth.
[Mini+] [MK3S+BEAR]
Publié : 04/08/2021 6:50 pm
1 personnes ont aimé
AlexLandherr
(@alexlandherr)
RE: Proper Concentration?
But still 90% concentration right? Or can I use something like 99.5-99.7% as where I live there's not much else available?
Publié : 04/08/2021 7:01 pm
RE: Yes, maybe, but probably not
Publié : 04/08/2021 7:14 pm
3 personnes ont aimé
AlexLandherr
(@alexlandherr)
Would Any Dish Soap Do It?
So would any dish soap like this one do it?:
https://en.wikipedia.org/wiki/Fairy_(brand)
Publié : 18/08/2021 1:41 pm
Fairy is a good UK equivalent to Dawn
Posted by: @alexlandherr
Yes, Fairy is a known UK equivalent to Dawn. The only reason Dawn and Fairy are mentioned is that they're known to work. That doesn't mean others can't work equally well. Do watch out for anything with hand softeners or other additives that can mess up your adhesion.
It doesn't help that many products get rebranded every few years.
Publié : 18/08/2021 2:46 pm
ColmMcG
(@colmmcg)
Membre
RE: Can I Use Any Isopropyl Alcohol Wipes with the Smooth PEI Sheet?
I noted the mention of the use of a bottle of IPA, Would it be appropriate to use this with a pack of make up removal pads ?
which are usually lint free so as to avoid blocking skin pores so should avoid leaving any tiny parts of cotton on the print sheet.
But I am also looking for some 90% proof wipes, as a method of circumventing the risks associated with leaving a 500ml bottle
out for all with access to the 3d printer to use, fire/drinking issues.  I may have health and safety issues on the brain here.
I expect I can just leave a smaller bottle beside each 3d printer. But individual wipes would be much safer and easier to document
as part of the process when using a 3d printer.
Regards Colm
Publié : 06/12/2023 12:39 pm
High percentage IPA, denatured alcohol, methylated spirit and overproof vodka all work about equally well as long as dishwashing detergent and HOT water are used from time to time to clear residues ... but I haven't bothered with alcohol cleaning for the last couple of years and I just use soap and water 'though I may swipe a failing smooth sheet with acetone sometime soon.
We say Dawn/Fairy as they are good, commonly available examples but most cheap, own-brand liquids are equally good; it's the upmarket versions with additives for 'extra sparkle' and the like that leave unwanted films.
Anyone drinking the type of IPA we refer to is not going to get the effect they expect (The other type, India Pale Ale, is a different matter but a lousy bed cleaner) - you might decant it into a poison bottle and label it '3D print bed cleaner' to reduce the chance of the chemically illiterate getting bright ideas.
The biggest difference I have seen, with school aged users, came from leaving a pack of latex gloves by the machine with instructions to use when handling the print sheet ... although not necessary they induced a cleanliness mindset 'though other precautions were required to prevent them being stolen as novelty balloons.
Publié : 06/12/2023 3:47 pm
