Bubble marks on smooth PEI sheet after removing print
shingdoh
(@shingdoh)
After removing my most recent print i noticed some small bubble marks on the printbed sheet along the outline of the object, most pronounced at the corners. The sheet is also visibly warped in those spots. They never appeared on a previous print.  What are those? Could they be related to the higher first layer temperatures, that input shaper needs? (230 vs 215 for PLA, which is what im using). This was my first "longer" (6-7 hours) print with the new input shaper profile.
And do i need a new sheet now?
Este debate ha sido modificado el hace 2 years por shingdoh
Respondido : 15/01/2024 3:11 pm
RE: Bubble marks on smooth PEI sheet after removing print
Bubbles like these often appear when a print has been firmly adhered to the build plate.
If you clean the other side of the build plate and use that, next time, the bubbles formed on this print will probably disappear
Respondido : 15/01/2024 3:43 pm
1 les gusta
shingdoh
(@shingdoh)
Posted by: @joantabb
Never noticed until now the other side of the sheet can be used for printing^^ Thanks, i´ll try that
Respondido : 15/01/2024 3:49 pm
The bubbles should disappear by themselves over time. If they spread to the entire printing plate, moisture could be a problem.
Carefully remove the print object only after the printing plate has cooled down completely.
wbr,
Karl
1 les gusta
