4.2.0-RC1 Firmware for Original Prusa MINI
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
Hi guys,
this is a testing release recommended to experienced users! There are major updates to the functionality, we would appreciate any feedback 😉
Summary
  • Firmware localized into 7 languages
  • Printer beeping in silent mode fixed
Detailed description
Until now, the firmware for the Original Prusa MINI was available only in the English language. With this release, we are adding support for more languages. Apart from English, users can now also select:
  • Czech
  • German
  • Spanish
  • French
  • Italian
  • Polish
Compared to the previous generations of the Original Prusa i3 printers, the MINI is able to change the language instantly. Also, thanks to a better LCD screen, there will be support for diacritical marks in the final release of the firmware. The entire firmware uses UTF-8 texts.
There are two ways how languages can be selected:
  • Via a prompt when the printer starts for the first time. This is a typical example of new printers leaving the factory and also if the firmware is updated to version 4.2.0. Once the language is set, the user won't be asked again, even after updating to higher versions than the 4.2.0.
  • The other option is to change language manually. Go to LCD Menu - Settings - Language and pick the desired language. As mentioned earlier, the change is instant.
wizard DE selftest DE
Examples of the user interface in German language
Integration of the languages is still in progress, diacritical signs will arrive in the final release. If you encounter any issues, please let us know.
Known issues:
  • Some parts of the NTP server are not translated (e.g. Today, tomorrow, days of the week)
  • On the Selftest screen, the text is wrapped incorrectly in all languages
In case the printer was switched to silent mode, but the filament sensor was present and activated, the printer kept beeping when the filament was absent (e.g. filament runout). This is now fixed and the printer remains silent even when the filament runs out.
Supported printer:
  • Original Prusa MINI
Download link:
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v4.2.0-RC1
How to flash the firmware on MINI:
  1. Copy the firmware file (.bbf) onto the USB drive with FAT32 formatting
  2. Insert the flash drive in the MINI's USB port
  3. Turn the printer ON (or reset it)
  4. A new screen will appear
  5. Confirm you want to flash the firmware
  6. Wait till the firmware is flashed and printer fully boots into the home screen
Please report any bug here:
github.com/prusa3d/Prusa-Firmware-Buddy/issues
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Postato : 24/07/2020 12:28 pm
Texy
 Texy
(@texy)
RE: 4.2.0-RC1 Firmware for Original Prusa MINI
The incorrect z height reported on the screen isn't fixed in this RC ?
Postato : 25/07/2020 9:22 am
1 persone hanno apprezzato
D.R.racer
(@d-r-racer)
@texy if you mean the Z-axis displaying the real Z-position including MBL compensation - no. FW 4.2 was only about localization and tiny fixes which were finished at the time of release.
Postato : 06/08/2020 5:46 am
