Siraya Tec PPA-CF - fine-tuning
jan.d.slay
(@jan-d-slay)
Hello everyone.
I only came into contact with PPA-CF when I got my Bambu Lab X1C, and I was immediately impressed by this type of filament.
Most recently, I used Creality PPA-CF, but I wasn't convinced by the print quality.
Now I've discovered Siraya Tec PPA-CF here in the forum and have printed it according to the manufacturer's specifications.
I think I'll create a profile with a maximum of 10% cooling. Even though I only printed at 305 degrees at the nozzle and 100 degrees bed temperature, I think the filament was too hot in some places.
Tomorrow I'll take pictures to compare.
Postato : 11/03/2026 7:23 pm
1 persone hanno apprezzato
RE: Siraya Tec PPA-CF - fine-tuning
Classic Benchy smokestack issue you see with all "hot" filaments. For ascetic reasons you can insert this at the start of the smoke stack layer:
M220 S50   ; Set print speed to 50%
M106 S102  ; Set fan to 40% (255 * 0.40 = 102)
Postato : 11/03/2026 7:27 pm
jan.d.slay
(@jan-d-slay)
Thank you. I'll test it out 🙂
Postato : 11/03/2026 7:31 pm
There is a high chance that if you print two Benchies together the problem will go away as the hot-end will move to the other one for long enough at each layer to allow cooling to complete.
Postato : 11/03/2026 9:53 pm
jan.d.slay
(@jan-d-slay)
Posted by: @hyiger
I only took 15%, which was enough. This time at 310 degrees. I'm still loading 3MF files.
Postato : 12/03/2026 3:14 pm
2 persone hanno apprezzato
Ruebarb
(@ruebarb)
Can't wait to print this, been sitting in my amazon cart for weeks.
Core One L MMU3, MK3S
Postato : 12/03/2026 4:47 pm
Posted by: @ruebarb
Just make sure you dry it at 80C+ (100 is better) for 12 or more hours before you print it.
Postato : 12/03/2026 5:17 pm
Ruebarb
(@ruebarb)
Thanks, my sunlu only goes to 70, waiting for my West3D Filament Toaster to ship.
Posted by: @hyiger
Posted by: @ruebarb
Postato : 12/03/2026 5:21 pm
jan.d.slay
(@jan-d-slay)
Hello, everyone.
The first real test with Siraya Tec PPA-CF was a two-hour print at 310°C to integrate the heat shield into the fan shroud.
The results, including the overhangs, are quite impressive.
Prusa PCCF on the left and Siraya Tec PPA-CF on the right
Postato : 22/03/2026 6:57 pm
Posted by: @jan-d-slay
My advice would be to anneal the part. I've noticed some part creep on unannealed PPA that essentially results in me having to periodically retighten screws. If I remember, Stefan at CNC Kitchen did a video on this awhile back.
Postato : 22/03/2026 9:21 pm
jan.d.slay
(@jan-d-slay)
That's what I plan to do with the hook from CNC Kitchen. I've already printed one that I didn't post-anneal, and I'm going to post-anneal the other one.
@Hyiger: What settings did you use? Online, you can find values ranging from 80 to 100 degrees and 4 to 8 hours. Does that mean 100 degrees for 4 hours and 80 degrees for 8 hours?
Postato : 23/03/2026 7:29 am
100 for 4 hrs. I'm using my solder reflow over for this.
Postato : 26/03/2026 9:47 pm
