Respooling on 2kg prusament spools
I just bought a 2kg buddy3d PEGT spool and they are huge and hard to store. I also happen to have an empty 2kg prusa spool, but I cannot find a spool rewinder for it. I was wondering if I missed it in printables and if so, could someone point me in the right direction.
Thanks
Best Answer by MHW:
Ended up finding the stuff I used these for the 2kg prusament spool and it worked well
https://www.printables.com/@Marie_2111228/collections/3382034
RE: Respooling on 2kg prusament spools
Here is one: https://www.printables.com/model/1617077-drill-powered-filament-re-spooler
there are more there to found.
Gert
I think I was thinking of a more fancy one as with this option, you do have to hold it pretty straight and 2kg and a drill is a bit awkward to hold steadily.
The pastamatic has a mod for 3 kilo spools and a motor to replace the drill.
It's a lot of hassle to motorize, and I would seriously consider the drill unless you have accessibilty needs.
Glad you got it sorted.
I find the pastamatic works much better when securely bolted down to something.
May I ask how is the hand crank? I have never used such a thing for a task like this.
Works well with the one spool I had, did not fell the need to bolt the pastamatic.
