225 is to cold 🙂
GertL
(@gertl)
225 is to cold 🙂
Just run a temp tower with PETG from Hyigers Prusaslicer-Calibration.
Very nice done @Hyiger.
Wich one looks best to you guys?
I will walk through each calibration then rerun the Califlower.
Gert
Postato : 04/04/2026 10:39 am
Conrad
(@conrad-2)
RE: 225 is to cold 🙂
My best temps for Elegoo PET-G Rapid are between 230 and 250 so I use 240. At 260 the bridge is a saggy mess. Even as low as 220 it still looks very good but I'd worry about adhesion. You also have to look under the overhangs, at the holes and at the surface finish on flat areas. I don't find temperature towers as clear cut as one might desire. OTOH, it's good if materials can perform well over a wide range so printing is less fussy.
Postato : 04/04/2026 2:21 pm
