Raspberry Camera V3 rattle
stevo1957
(@stevo1957)
I have a Raspberry camera V3 mounted on the X axis motor of my MK4S.
When the extruder moves up and down, the black lens surround rattles.
I have asked another user (thanks Walter) who has this camera whether theirs does the same. The lens surround ring on theirs is also loose but given it is a fixed mount in an enclosure, there is no rattle during printing.
Given the autofocus feature of the V3 camera I'm thinking it is probably working as it should with the rattle only developing due to the camera being mounted and moving up and down the Z axis. Printhead movements are probably causing resonance down through the mount too, contributing to the noise.
Are their any other V3 camera owners who experience this rattle?
Veröffentlicht : 20/03/2025 9:17 pm
Valentin
(@valentin-2)
Mitglied
RE: Raspberry Camera V3 rattle
Hey yes i experience the same. I have either the same or a similar mounting option as you. I am not sure if the rattle comes from the lense surround ring ratteling against my camera cover or if it would rattle by itself. i am working on a modified camera housing removing the option for the ring to rattle against the cover.
Veröffentlicht : 16/11/2025 12:20 am
