Quick Connect for Bowden Tube into Nexruder?
moell
(@moell)
Happy Camper here-just finished upgrading MK4 to MK4S + MMU3.  Works great after tweaking filament sensors on both units.
Question - is there such a connection that allows the Bowden tube from the MMU3 to be easily removed from the Nextruder to allow the printer to run in non MMU mode (turn off MMU in MK4S “settings”)?  Now I unscrew the Bowden tube fitting to do this.  A quick connect for the Bowden tube would be awesome.  I haven’t found such a fitting yet.
Publié : 03/12/2024 11:25 am
Tomáš Jančík
(@tomas-jancik)
Membre
RE: Quick Connect for Bowden Tube into Nexruder?
I only disconnect the tube from the fitting, leaving the fitting in nextruder. Have only done smaller prints so far, but works ok
Publié : 03/12/2024 11:37 am
iftibashir
(@iftibashir)
Posted by: @tomas-jancik
This is how it should be done. The PTFE tube is already quick connect. There is no need to remove the fitting itself - just press the collet to remove the PTFE tube. Once done, push the PTFE tube back down into the fitting where the fitting will grab and hold in place. Simple.
Publié : 03/12/2024 12:26 pm
I'm using this
https://www.printables.com/model/873440-magnetic-twist-lock-ptfe-connector
Works great
Publié : 03/12/2024 4:58 pm
moell
(@moell)
foxrun3d - you the man.  Exactly what I was looking for.  Thx.
Publié : 03/12/2024 7:32 pm
stevo1957
(@stevo1957)
Regularly removing the bowden tube from the festo connectors on either the MMU or Nextruder is not a good idea as over time, the ends of the PTFE tube become distorted / damaged.
The use of the magnetic connector that FoxRun3D has referenced is by far the better solution. I use this setup when I want to print external to the MMU3 or when I use flexible filament and it has been 100% successful, with zero issues after plenty of single colour prints.
Publié : 05/12/2024 8:57 pm
Steve
(@steve-4)
If you don't have an MMU, why do you need a PTFE tube?  I have an MK4, and filament  feeding is fine without a PTFE tube.  Anyway, the PTFE tube is simply a guide.  The Nextruder is direct drive and does not need a Bowden tube.
I have an XL, and have the PTFE tube guide ends just hanging near the Nextruder and not connected with the couplings.  Works better, easier to change filaments,  and  doesn't need any fancy couplings.  The PTFE tubes are just filament guides anyway, not Bowden tubes.  I am considering changing them out for 3mm tubes since I don't like the small tube size.
Senior Life member of IEEE.
Publié : 10/12/2024 4:14 pm
Steve
(@steve-4)
Anyway, the filament paths on the latest Prusa printers is excessively convoluted.
Publié : 10/12/2024 4:15 pm
moell
(@moell)
One of my MK4S' is used both with and without the MMU3, depending on my printing needs.  The other MK4S is in the factory condition.
Publié : 10/12/2024 4:23 pm
moell
(@moell)
I changed the Bowden tubes to 3mm ID for the MMU3 usage.  The upstream end of the tubes are fed directly from three Eibos filament dryers in free axle rotation mode.  I have not had any issues with the filament feed into the MMU and through either filament sensor (MMU and Nextruder).
Publié : 10/12/2024 4:27 pm
Steve
(@steve-4)
Those aren't Bowden tubes, they are filament guides.  With filament guides, changing them to 3mm simply makes it easier to load filament.  If they were really Bowden tubes, changing the size would make a world of difference.
In a Bowden extruder setup, the filament drive mechanism is separated from the actual hotend by an appropriately-sized PTFE tube.  The drive mechanism pushes the filament into the hotend by way of the PTFE Bowden tube.
Publié : 10/12/2024 4:41 pm
Walter Layher
(@walter-layher)
They are nedwoB ... 🙂
Publié : 10/12/2024 4:52 pm
1 personnes ont aimé
Sembazuru
(@sembazuru)
Posted by: @walter-layher
I was going to say "reverse bowden" since that is what it is generally called and no one else had settled on that phrase, but I prefer your term. 🤣
See my (limited) designs on:
Publié : 24/12/2024 11:07 pm
Michael Eck
(@michael-eck)
Membre
RE: FITTING for Bowden Tube into Nexruder?
Anyone have a recommendation for a fitting into the nexruder for a filament guide. I'm thinking of using a Creality dryer. Looks like the PTFE tube is 4mm? I don't recall that the 4S came with this fitting, so not sure about the thread size. I love the quick connect idea, but does it share the same size threads as the Nexruder. Thoughts anyone? Can't find this fitting on Prusa's site - at least as it applies to the MK4S.
Publié : 11/01/2025 6:51 pm
try this
https://www.prusa3d.com/product/fitting-m5-4/
Publié : 12/01/2025 12:53 am
Thoughts anyone?
Screw the M5-4 connector linked to by Joan into the Mk4S, run a short PTFE tube from it to an PC4-M10 or M6 connector screwed into the magnet quick connector, then a PTFE tube from the second PC4-M10/M6 in the magnetic connector to your dryer (I use PC4-M10 because I have oodles of them lying around).
Publié : 12/01/2025 2:58 pm
