Print PEI: MK4 High Temp 450 °C mod is here!
Seite 1 / 2
metacollin
(@metacollin)
This handsome benchy was printed on a MK4 using this mod at 390*C in PEI-GF30 filament.
This mod is a combination firmware and hardware mod, but the hardware modification is extremely basic and amounts to things you will probably need to do anyway one day (replacing parts of the hotend).
This replaces the hotend thermistor with a PT1000, but most importantly, it does so with almost no loss in resolution and without any resistor swapping or external amplifiers or anything else. Just a PT1000's wires spliced directly to the loveboard's hotend thermistor connector.
In fact, I am testing a version of the firmware that can use a PT1000 with no loss in resolution, however there are minor side effects and it is unclear if this is necessary, as the standard version of my high temp firmware seems to work great and has zero side effects. I may release it but at this point, it is unclear if there is any real benefit.
I designed this mod to be as easy to achieve as possible, but it will require some very basic soldering of two wires (the PT1000 leads).
You can find the firmware in the 'releases' on my github repo for the high temp firmware, as well as detailed information on what it does, how it does it, and instructions and links to parts needed for the hardware modifications. The repo is the primary source of the latest information/instructions/etc, so check it out if interested:
https://github.com/metacollin/Prusa-Firmware-Buddy
Veröffentlicht : 07/05/2025 3:38 am
3 weiteren Personen gefällt das
altaic
(@altaic)
RE: Print PEI: MK4 High Temp 450 °C mod is here!
Hell yeah! I’ve been working on a similar mod for my Core One 🙏
Veröffentlicht : 07/05/2025 9:15 am
Fil4ment
(@fil4ment)
That is a spectacular trick! I absolutely love it. Thanks for posting this!
Veröffentlicht : 07/05/2025 10:58 am
Fil4ment
(@fil4ment)
One question on this: Your github says you can't use brass nozzles, anymore. That's just a temperature issue, right? If so, then I would still be able to use brass for lower temperature materials, which is my plan. Having a separate aluminum heatblock for using brass OEM Prusa nozzles, so I can swap nozzle sizes easier, and then the nickel plated copper heatblock for use with hardened steel nozzles at higher temperatures, for abrasive and higher temperature filaments.
Veröffentlicht : 07/05/2025 12:23 pm
metacollin
(@metacollin)
Posted by: @fil4ment
Yes, I should have qualified that statement by saying you can't use them for high temperature printing. They work just fine at for <300*C. And it isn't the end of world if you do use them at higher temperatures - they won't just stop working AFAIK. Brass doesn't melt until 900*C+.
It begins to soften at 300*C however, so I think the reasoning is that they'll wear  out very quickly and even non-abrasive filament at higher temperatures can begin to widen the nozzle hole. I haven't actually bothered to test, so I couldn't tell you how quickly this happens or how much of a concern it really is, but regardless, it shouldn't be an issue below 300*C.
Veröffentlicht : 07/05/2025 11:23 pm
metacollin
(@metacollin)
Posted by: @altaic
I think all the critical changes in my branch should work without modification for the Core One as well, feel free to steal any of the code you want if its useful or helpful for your mod!
Veröffentlicht : 07/05/2025 11:37 pm
altaic
(@altaic)
Posted by: @metacollin
I think all the critical changes in my branch should work without modification for the Core One as well, feel free to steal any of the code you want if it’s useful or helpful for your mod!
Looking forward to it! I’m shooting for 350C since I’m not planning to print the super expensive filaments (PEEK, PAEK, PEI/Ultem, etc.) in the immediate future, so I got a CHC heater w/ PT1000 that should do the trick.
It’ll be a little while before I can get to the mod, however, since I’m currently blocked by troubleshooting and fixing my C1’s teething issues. Need to get everything working reliably before experimenting.
I’ll send any feedback your way, though, here or on GitHub. Thanks again for doing all the work and PoC— really awesome.
Veröffentlicht : 08/05/2025 7:02 am
Fil4ment
(@fil4ment)
any chance of submitting a pull request, to get your code integrated into official firmware?
Veröffentlicht : 10/05/2025 12:26 pm
metacollin
(@metacollin)
I can try, but my past experience with Prusa is they tend to be extremely reluctant to merge anything that falls outside the scope of the stock/supported printer configurations unfortunately. I had a couple of PRs, including one that was simple bug fix (but was only a bug for non-standard printer configurations) and despite a large number of people pleading that it be merged in the PR thread, it never was.
I don't even really disagree with this policy - Prusa is a for-profit business, and they are kind of on the hook to support the code that they merge into the firmware, so it is really just making more work for them for no benefit.
Diese r Beitrag wurde geändert Vor 12 months von metacollin
Veröffentlicht : 13/05/2025 1:44 pm
Fil4ment
(@fil4ment)
It would only benefit them if they offered the high-temperature kit as a complete hotend assembly. Which would be challenging to justify.
Veröffentlicht : 13/05/2025 3:19 pm
FordPrefect
(@fordprefect)
Mitglied
I just stumbled upon this and it sounds great, I already run an E3D diamond nozzle so with the thermistor swap and firmware flash I should be golden. Do you intend to include the latest official firmware updates in your version soon? I ask because that update fixed the BSOD on filament loading that I had painfully often when loading custom filaments.
Veröffentlicht : 27/09/2025 7:33 pm
SciPrint
(@sciprint)
Won't the diamond fall out at this temp? I think they are rated for 300C and I believe I read they slowly turn to graphite at higher temps?
Veröffentlicht : 08/01/2026 1:31 pm
jan.d.slay
(@jan-d-slay)
Hello @metacollin 🖐️
I would like to take this opportunity to express my sincere gratitude for your excellent preparatory work on GitHub.
Your fork was the basis for the firmware for my Prusa Core One HT.
Thank you very much. 👍 👍
Veröffentlicht : 23/02/2026 7:39 pm
Mitglied
Do you really print that on the standard surface?
Veröffentlicht : 24/02/2026 10:08 am
SciPrint
(@sciprint)
Show us something you printed.
Veröffentlicht : 24/02/2026 10:20 am
jan.d.slay
(@jan-d-slay)
Posted by: @sciprint
I'll do that.... as soon as I get home 😉
Veröffentlicht : 24/02/2026 11:18 am
LarGriff
(@largriff)
Must be a long trip home…
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 10/04/2026 1:39 pm
jan.d.slay
(@jan-d-slay)
You'll laugh, but I'm still driving 😉 ..... and suddenly I'm in the mood for "Driving Home for Christmas Printing" again. Joking aside, I'm currently working on my chamber heater and the firmware to keep the printer stable between 60 and 70 degrees.
Veröffentlicht : 14/04/2026 3:01 am
Caroline
(@caroline)
Thank you SO MUCH, this is brilliant!
Any chance on also implementing these changes to the Prusa XL?
Could you please share your insights on what you think might be different compared to the Core One?
Veröffentlicht : 22/04/2026 4:31 pm
Differential expansion will loosen any different material insert so yes, you risk losing the diamond tip.
Not at speeds likely to worry you, however, like coal, they are carbon so eventually they burn.
Veröffentlicht : 22/04/2026 5:13 pm
Seite 1 / 2
