OctoPrint: M601 Printhead doesn't stay in the back during the pause
Doagl
(@doagl)
Hey guys! I really hope you can help me. I print via OctoPrint. The following problem occurs: every time I set a pause in the slicer my printer makes one. But normally the printhead should stay in the upper left corner. It does for a very short time. Then it comes back to the position it  later starts the print again. I don't have a clue and my "Marlin" isn't that good. What I have tried yet:
  • Set up OctoPrint properly (GCODE scripts, etc.)
  • googled for a lifetime
  • logged a print
Thx a lot for your help and your competence!
Cheers 😉 Matthias
2024-11-19 10:13:31,637 - Send: N477 M117 79% L=4/6*87
2024-11-19 10:13:31,642 - Recv: ok
2024-11-19 10:13:31,648 - Send: N478 G1 X129.357 Y109.357 Z.65*119
2024-11-19 10:13:31,739 - Recv: ok
2024-11-19 10:13:31,741 - Send: N479 M74 W0.0607659*72
2024-11-19 10:13:33,006 - Recv:  T:224.26/225.00 B:59.87/60.00 X:37.05/36.00 A:50.87/0.00 @:74 B@:80 HBR@:154
2024-11-19 10:13:33,498 - Recv: ok
2024-11-19 10:13:33,502 - Send: N480 M117 NFC*67
2024-11-19 10:13:33,505 - Recv: ok
2024-11-19 10:13:33,507 - Send: N481 M601*41
2024-11-19 10:13:33,522 - Recv: ok
2024-11-19 10:13:33,523 - Recv: echo:enqueueing "M118 A1 action:pause"
2024-11-19 10:13:33,524 - Recv: // action:pause
2024-11-19 10:13:33,525 - Pausing on request of the printer...
2024-11-19 10:13:33,525 - Changing monitoring state from "Printing" to "Pausing"
2024-11-19 10:13:34,301 - Send: N482 G1 X129.357 Y109.357*37
2024-11-19 10:13:34,303 - Recv: ok
2024-11-19 10:13:34,304 - Send: N483 M400*40
2024-11-19 10:13:35,007 - Recv:  T:223.92/225.00 B:59.91/60.00 X:37.00/36.00 A:50.94/0.00 @:90 B@:54 HBR@:155
2024-11-19 10:13:36,305 - Recv: echo:busy: processing
2024-11-19 10:13:37,008 - Recv:  T:223.86/225.00 B:59.79/60.00 X:37.05/36.00 A:50.94/0.00 @:91 B@:96 HBR@:156
2024-11-19 10:13:38,306 - Recv: echo:busy: processing
2024-11-19 10:13:39,008 - Recv:  T:223.43/225.00 B:59.84/60.00 X:37.04/36.00 A:51.00/0.00 @:107 B@:62 HBR@:157
2024-11-19 10:13:39,828 - Recv: ok
2024-11-19 10:13:39,836 - Send: N484 M114*47
2024-11-19 10:13:39,840 - Recv: X:129.36 Y:109.36 Z:20.65 E:-1.70 Count X:12936 Y:10935 Z:8549
2024-11-19 10:13:39,846 - Recv: ok
2024-11-19 10:13:39,855 - Send: N485 M601*45
2024-11-19 10:13:39,887 - Recv: ok
2024-11-19 10:13:40,686 - Changing monitoring state from "Pausing" to "Paused"
2024-11-19 10:13:41,008 - Recv:  T:223.16/225.00 B:59.77/60.00 X:37.14/36.00 A:51.05/0.00 @:115 B@:85 HBR@:160
2024-11-19 10:13:43,009 - Recv:  T:223.62/225.00 B:59.83/60.00 X:37.26/36.00 A:51.12/0.00 @:95 B@:60 HBR@:169
2024-11-19 10:13:45,010 - Recv:  T:224.32/225.00 B:59.77/60.00 X:37.25/36.00 A:51.18/0.00 @:69 B@:82 HBR@:168
2024-11-19 10:13:47,010 - Recv:  T:224.36/225.00 B:59.83/60.00 X:37.43/36.00 A:51.26/0.00 @:78 B@:66 HBR@:171
2024-11-19 10:13:48,144 - Recv: echo:enqueueing "M118 A1 action:resume"
2024-11-19 10:13:48,145 - Recv: // action:resume
2024-11-19 10:13:48,146 - Resuming on request of the printer...
2024-11-19 10:13:48,146 - Changing monitoring state from "Paused" to "Resuming"
2024-11-19 10:13:48,194 - Send: N486 M602*45
2024-11-19 10:13:48,217 - Recv: ok
2024-11-19 10:13:48,221 - Changing monitoring state from "Resuming" to "Printing"
2024-11-19 10:13:48,224 - Send: N487 M73 Q58 S0*35
2024-11-19 10:13:48,231 - Recv: ok
2024-11-19 10:13:48,241 - Send: N488 G1 Z.65 F720*40
2024-11-19 10:13:48,251 - Recv: ok
2024-11-19 10:13:48,267 - Send: N489 G1 E.7 F1500*51
2024-11-19 10:13:48,278 - Recv: ok
2024-11-19 10:13:48,290 - Send: N490 G1 F1902*73
2024-11-19 10:13:48,295 - Recv: ok
2024-11-19 10:13:48,297 - Send: N491 M73 P58 R0*36
Posted : 20/11/2024 8:45 am
Walter Layher
(@walter-layher)
RE: OctoPrint: M601 Printhead doesn't stay in the back during the pause
Do your settings in OctoPrint for the Gcode scripts look like in the screenshot?
Posted : 20/11/2024 9:01 am
Doagl
(@doagl)
Yeah... almost... but yes 😉
Posted : 20/11/2024 9:10 am
Walter Layher
(@walter-layher)
Ah, I see the "M604" in the first line of the first text box is not visible in the screenshot, but it is there.
So the printhead of your MK4 does not stay indefinitely in pause if you have set a pause in PrusaSlicer?
I have used my MK4 with OctoPrint for embedding clear plastic sheets into prints with a pause set in PrusaSlicer for this model here. The printer waited indefinitely until I hit "resume" on the printer display, which one time was at least half an hour. I have attached my PrusaSlicer project for the cover of one of these boxes. Perhaps you could compare the project with your settings in PrusaSlicer if there is a difference?
Posted : 20/11/2024 10:45 am
