Abrasive filaments: which nozzle should I use?
Lvet
 Lvet
(@lvet)
I have an MK4S with the stock HF0.4 nozzle and would like to test printing with carbon fiber filaments. Since these are abrasive, I understand that I should replace the existing nozzle with a hardened one. Are there any hardened nozzles on the market that are directly compatible with the MK4S, or will I need to purchase the V6 Nozzle Adapter?
I’m a bit confused about the available options.
Best Answer by JP Guitars:
Here you go:
https://www.prusa3d.com/product/e3d-prusa-nozzle-high-flow-obxidian-0-4-mm/
You can also use a V6 Nozzle and an adapter, which is what I do as when I wanted one I could not get a nextruder version
Postato : 12/11/2024 2:31 pm
JP Guitars
(@jp-guitars)
RE: Abrasive filaments: which nozzle should I use?
Here you go:
Postato : 12/11/2024 2:41 pm
1 persone hanno apprezzato
Lvet
 Lvet
(@lvet)
Posted by: @jp-guitars
Here you go:
Thanks 😀
Unfortunately it's out of stock. I see there is also a: "Prusa Nozzle ObXidian - 0.4 mm" not High Flow.
https://www.prusa3d.com/product/prusa-nozzle-obxidian-0-4-mm-2/
Is there going to be a substantial difference in printing speed?
Postato : 12/11/2024 7:09 pm
JP Guitars
(@jp-guitars)
Sorry, no idea. I've got a mk4 with mmu so no use for the high flow on mine.
In the UK at least there are a few other suppliers for obxidian nextruder nozzles, for instance those below so worth searching where you live
https://e3d-online.com/products/genuine-e3d-obxidian-high-flow-prusa-nozzles?variant=41687283302459
https://www.123-3d.co.uk/E3D-Prusa-Nozzle-High-Flow-Obxidian-0-4mm-i11800-t135738.html
Postato : 12/11/2024 7:18 pm
Lvet
 Lvet
(@lvet)
Thanks again! 😀 I found the High Flow nozzle through a local supplier here in Spain.
One additional question: Do I need to adjust the temperature because the nozzle isn’t made of brass?
I assume the metal in the ObXidian nozzle has a different heat transfer coefficient than brass.
Postato : 12/11/2024 9:14 pm
JP Guitars
(@jp-guitars)
No, leave it the same
Postato : 12/11/2024 9:47 pm
