A bit confused about the nozzles.. CHT vs. HF
Página 1 / 2
thilo.domsdorf
(@thilo-domsdorf)
Miembro
Hi there,
just finished the upgrade of my MK4 to MK4S, which obviously included the CHT 0.4 mm nozzle.
Do I have to change the printer type in Prusa Slicer accordingly from the standard "MK4 0.4 mm" nozzle to a "MK4S HF0.4 mm" nozzle?
Simply asked, is "CHT" equivalent to "HF"?
And, since I bought a ObXidian hardened nozzle a while back, would the change to that nozzle require the change in Prusa Slicer back to standard 0.4 mm again?
Or is ObXidian a "HF" nozzle type as well as "CHT", maybe?
Thanks in advance,
Thilo
Best Answer by FoxRun3D:
Yes, CHT is HF.
No, Obxidian is not HF (but you can now also set Hardened as a nozzle type on the printer, which is what Obxidian is)
I noticed they now also offer a Obxidian high flow nozzle, in addition to the regular Obxidian, to make things even more complicated.
Respondido : 18/10/2024 2:50 pm
1 les gusta
RE: A bit confused about the nozzles.. CHT vs. HF
Yes, CHT is HF.
Respondido : 19/10/2024 5:45 pm
1 les gusta
Sembazuru
(@sembazuru)
CHT is a brand name for a high-flow internal geometry that BondTech patented. AFAIK, E3D (who actually makes the Nextruder nozzles for Prusa) licensed the CHT technology from BondTech to use on both their CHT Revo nozzles as well as the CHT Nextruder nozzles that they are making for Prusa. I'm not sure what technology the E3D "highflow" nozzles (that don't mention CHT) use.
See my (limited) designs on:
Respondido : 21/10/2024 9:57 pm
thilo.domsdorf
(@thilo-domsdorf)
Miembro
In the meantime, I read again thru tue upgrade guide from MK4 to MK4S and noticed a sentence that I didn't pay enough attention to forehand:
(What's in the kit)
"New high-flow Prusa Nozzle CHT."
Shame on me, the information I was searching was already there.. CHT is High-Flow.
So I changed the printer profile in Prusa Slicer to the MK4S 0,4mm HF-nozzle.
The speed of the MK4S ist truly amazing, although I didn't measure the difference between standard and HF nozzle.
The upgrade to MK4S is worth the money.
BTW: I'm pretty sure I can use the ObXidian nozzle that I bought a while ago, although that's not the HF type, which I now recognized. A HF version is available as well. I'll just change to ObXidian when I print some filament with carbon or glass fibre in it. Doesn't happen too often though.
Thanks to all who read and or answered my post.
Cheers!
Thilo
Respondido : 22/10/2024 7:57 am
1 les gusta
Jonnie Cache
(@jonnie-cache)
After reading this, I wanted to learn more about the CHT (Core Heating Technology) nozzles. In case anyone is interested, here is a blog post about it from Bondtech.
https://www.bondtech.se/2024/03/04/unleashing-core-heating-technology-cht-in-3d-printing-a-game-changer-for-all-scales/
Respondido : 15/11/2024 10:04 pm
melted pellets
(@melted-pellets-2)
Posted by: @sembazuru
The prusa "HF" nozzles, brass and obXidian, are the same profile as the Revo HF's.  Also, If you have (a clean one) in hand, the two-piece machined section is obvious around the tip.
https://e3d-online.com/blogs/news/revo-high-flow
Respondido : 29/11/2024 5:07 am
belousevgen
(@belousevgen)
Miembro
If CHT is HF then why do they have both in stock? What is the difference between then except the price?
E3D Prusa Nozzle: High Flow Brass - 0.4 mm | Original Prusa 3D printers directly from Josef Prusa
Prusa Nozzle brass CHT - 0.4 mm | Original Prusa 3D printers directly from Josef Prusa
Respondido : 20/12/2024 8:58 pm
carlmmii
(@carlmmii)
Internal Geometry. The CHT nozzle was added first, likely based off of BondTech's CHT design. The HF nozzles are specifically E3D design, and came with the introduction of the MK4S.
Posted by: @belousevgen
Respondido : 22/12/2024 8:52 am
Dale DiDomenico
(@dale-didomenico)
Miembro
Curious why the prusa slicer has the same settings profile for speed regardless of CHT or HF nozzle used... I thought the whole point for HF nozzle was to print faster. Maybe, they didn't update the profiles yet...
Respondido : 29/12/2024 2:07 pm
Sembazuru
(@sembazuru)
Posted by: @dale-didomenico
CHT is a type of HF. (Read the above thread.)
Respondido : 31/12/2024 7:05 am
Dale DiDomenico
(@dale-didomenico)
Miembro
My point is the prusa profiles don't take advantage of the HF/CHT nozzle by using the same volumetric output in standard or HF nozzle settings.
Respondido : 31/12/2024 12:47 pm
belousevgen
(@belousevgen)
Miembro
Right! I had the same question. What is the point of buying two nozzles if they are both HF?
I understand they have different internal geometry. Does it mean they have equal performance or different?
So far we have different prices and geometry, but we have no clue how to take advantage of it or decide which one to buy.
Respondido : 31/12/2024 2:52 pm
Sembazuru
(@sembazuru)
Are you sure about that? The last time I checked (a week or two ago) there was a volumetric flow difference between the Prusament PLA loaded with a MK4S printer profile active vs the Prusament PLA loaded with a MK4S HF printer profile active. I didn't check other filaments.
Found it, check my message here: https://forum.prusa3d.com/forum/prusaslicer/high-flow-nozzle-setting-does-it-do-anything/#post-731205
Respondido : 06/01/2025 10:12 pm
strjan
(@strjan)
I'm also wondering about the difference. From the reading of Bondtech and e3d releases, I understand that the designs are different, with e3d pushing it seemingly a bit further.
Few notices I gathered:
1) product page for the e3d variant explicitly mentions 4 channels. I think Bondtech imaging shows 3
2) CNCkitchen has video about CHT, where he dissect the nozzle and speculates, how it is made. His idea is, that the geometry is made by 3 drills at angle. When you look at the models of e3d, the splitter, it is probably more complicated. The core seems to me to have bigger mass.
All speculations. It would be really nice to see, if there is difference in performance or reliability.
Respondido : 07/02/2025 4:22 pm
REB
 REB
(@reb-3)
Well at least I'm not the only one confused.  I have both and the internal geometry is definitely different.  I haven't tried the e3d nozzle yet and honestly I bought it by mistake.  I may try and do a flow test but with work and other things it wont be anytime soon.
chte3d
Respondido : 23/07/2025 4:23 pm
1 les gusta
LarGriff
(@largriff)
Great pictures!  It’s interesting that one has 4 paths and the other has 3.  But which picture is which nozzle?
Posted by: @reb-3
chte3d
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Respondido : 29/07/2025 1:30 pm
REB
 REB
(@reb-3)
Posted by: @largriff
The one with three paths is the CHT and four is the E3D.
Respondido : 29/07/2025 1:57 pm
1 les gusta
3DMason
(@3dmason)
So just to confirm, a stock MK4S comes with a E3D HF nozzle?
Respondido : 10/09/2025 1:07 am
LarGriff
(@largriff)
Posted by: @3dmason
No, it comes with a High-flow Prusa Nozzle brass CHT - 0.4 mm
Esta publicación ha sido modificada el hace 8 months por LarGriff
Respondido : 11/09/2025 3:26 pm
3DMason
(@3dmason)
OK thanks for the clarification.  So the benefits of replacing the CHT with an E3D HF nozzle would not be very noticeable then in retrospect, unless I switch to a larger nozzle diameter, like 0.6mm.  However, I'm wondering if E3D HF nozzles are even compatible with the supplied MK4S Nextruder design, or the silicone boot that comes with it?
Respondido : 11/09/2025 4:21 pm
Página 1 / 2
