A bit confused about the nozzles.. CHT vs. HF
Seite 2 / 2
dimijimi
(@dimijimi)
Mitglied
RE: A bit confused about the nozzles.. CHT vs. HF
Indeed in https://help.prusa3d.com/article/prusa-nozzle-types-for-nextruder-printers_928993 you can see that it says it's 3 vs 4 splits internally as said above
Prusa Nozzle CHT® nozzles split the filament into 3 thinner strands, while E3D Prusa Nozzle: High Flow has a unique internal geometry that splits the filament into 4 channels.
I have though bought a 0.8mm high flow from E3D and I can only get 15mm3/s which seems abysmall for both high flow or normal flow. Has anyone tested what flow they can get from the CHT or the high flow from a nextruder? Mine was on an XL
Veröffentlicht : 11/11/2025 9:15 pm
LarGriff
(@largriff)
Posted by: @dimijimi
You *should* get higher flow but only if all 3 (or 4) channels are clear.  Often one or more channels can get clogged (since each channel is a fraction of the nozzle diameter) and you end up with a partially clogged nozzle with a flow rate that’s worse than standard and very difficult to unclog.  That’s the flaw almost no one ever mentions, and why I rarely use HF (or CHT) nozzles.
Diese r Beitrag wurde geändert Vor 6 months von LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 13/11/2025 2:54 pm
Seite 2 / 2
