What am i doing wrong.
Michel Weber
(@michel-weber)
my settings where for generic ABS nozzle temperature 260° i set it to 240° because 260° was more then the ABS was made for but i still got this. Higher temperature causes a worse result i tried lower printing speed lower temperature etc. i have no clue whats wrong.
Napsal : 18/01/2025 8:46 pm
miroslav.h4
(@miroslav-h4)
RE: What am i doing wrong.
Everything! In the dark picture there is some shapeless spaghetti monster, resembling a mythical monster. There are some experiments with color change (orange spots), in the upper corner you can see a part of an object and that's about it. And do you want advice on this? We don't know what the result is, just some confused talk about temperatures. You can see that this is your first post, so check out other similar questions here on the forum to know how to ask. And when you know how to do it, feel free to ask again and better, surely someone will try to answer you. I know, this answer is different than you expected, but in this situation it is the only possible one.
Napsal : 19/01/2025 6:02 am
1 lidem se líbí
Save your project as a .3mf file
Files > Save Project as
Napsal : 19/01/2025 12:00 pm
1 lidem se líbí
