Weird results on print with letters
AvariCe
(@avarice)
Hello all,
This happened yesterday. The print is completed, and the for the layers of the letters, the colour is different. It is otherwise fine. The problem appears to on the layers with letters. Also, I had a ghost benchy in the same print with this model, and it came out fine. The material is Esun silk pla, and the profile is the default input shaper speed. Could you please help me troubleshoot it?
Best Answer by Diem:
The extra travel and speed changes mean those layers have more time to cool before the next layer is applied.  If you slow the print the effect will reduce.
Postato : 05/10/2024 8:34 am
Postato : 05/10/2024 11:50 am
1 persone hanno apprezzato
AvariCe
(@avarice)
RE: Weird results on print with letters
Thanks, though the problem isn't strictly solved, you have to try to see the band of lighter colour.
For whomever has the same problem, the setting I changed is Print Settings --> Speed --> box labeled speed for print moves --> set external perimeters to 35.
I saved the config as a preset for silk pla and hopefully won't have any more issues.
Postato : 05/10/2024 5:37 pm
