TPU What Sheet????
Outforawalk
(@outforawalk)
TPU What Sheet????
Ok Which piece of metal do I use to Print TPU material. I thought it was The satin sheet TF-21 or IT-22 I have these two and one more for PETG I believe  BH-25
Whic sheet do I use to print TPU  I did use it to make a couple small parts Put it took alot of effort to remove.  Help Me and be nice I am not technical in any way I use only standard sertting and I have very good results and I DO NOT use anything on my build surface Squecky clean is the only way I run
Opublikowany : 18/06/2025 4:33 pm
RE: TPU What Sheet????
last time i used tpu, it was on a smooth PEI sheet, after printing I let the sheet cool, then dribbled isopropyl alcohol around the base of the model, allowed it to soak for a couple of minutes, then gently peeled the print off the build plate.
this approach also works on satin and textured build plates and with petg prints
Opublikowany : 18/06/2025 4:44 pm
1 ludzie polubili
barney15e
(@barney15e-2)
The textured sheet should work without glue.
For the Satin or PEI, you need glue stick for a release agent. See the Filament Guide. TPU is in the Flex category.
https://help.prusa3d.com/filament-material-guide
Opublikowany : 07/08/2025 8:44 pm
