Thermal runaway during normal operation
pa3cw.radio@gmail.com
(@pa3cw-radiogmail-com)
I was breaking my head what went wrong printing a small component with PETG.  It seemed the printer was unable to keep the bed temperature.  The indicated temperature decreased resulting in a thermal runaway error.   Measuring the actual bed temperature gave a value much higher than the set temperature!  What goes wrong here is that, whilst printing a small component in the middle of the sheet, the blower cool the area where the thermistor is located. The thermistor is fooled and the bed will heat up further.  The indicated temperature drops fast however and the printer runs into an error.  I was able to avoid this placing the component in a corner of the build sheet instead of the middle.  I am not happy with this behavior. Is there a solution? Locating the thermistor on another spot?  Or even better, mounting more thermistors and take the average temperature to control the heatbed?  Who recognizes this?
Thanks,
Dick CW
Veröffentlicht : 21/12/2024 12:21 pm
RE: Thermal runaway during normal operation
this has been an issue for a long time, however it is relatively rare. the thermistor should be towards the left side of the middle of the heatbed, so most of the time, the extruder is moving over a relatively large area including the thermistor area, and the cooling effect over the thermistor is relatively small,
however if you have a single small part to the left side of centre, then all bets are off...  because the extruder spends more time over the thermistor area...
Veröffentlicht : 21/12/2024 12:43 pm
Or print multiple copies of the component so the extruder doesn't need to stay in place. Or even just a small cube somewhere else.
Veröffentlicht : 21/12/2024 1:16 pm
JGeiger2024
(@jgeiger2024)
I had this problem right after I upgraded my MK4 to MK4S.  Basically what was happening is that the print fan running at a high speed was cooling the extruder as well, and the heater couldn't keep up.  After much time on a support chat, the only thing that solved the issue was to add the silicon sock (and make sure that it is turned on under the hardware setup on the printer).
Veröffentlicht : 22/12/2024 9:54 pm
