Strange deformation on one side of rectangular opening in vertical wall of a print
Steve Elves
(@steve-elves)
This seems to happen every time I print.  I'm printing an enclosure case for a small IoT project; the case has some rectangular holes designed for display, access to SD card, etc.  On one side of each cutout there is a strange ripple effect (see photo), which is not found on the opposite side of the hole.  I'm assuming it's some sort of acceleration/deceleration effect, but I don't know for sure.  This appears on the X-axis sides of the print; I've tested the tension of the X belt and it seems OK.  Anything else I should try to diagnose this?
Best Answer by Diem:
You are using a SPEED profile which trades quality for time ... try using a STRUCTURAL or QUALITY profile and even a non Input Shaper printer profile.
Opublikowany : 15/08/2024 6:39 pm
RE: Strange deformation on one side of rectangular opening in vertical wall of a print
Files > Save Project as
Opublikowany : 16/08/2024 12:53 pm
Steve Elves
(@steve-elves)
Here it is...
Thanks!  I hope you find something.
Gerard Fridge Box
Opublikowany : 16/08/2024 2:59 pm
Just For Fun
(@just-for-fun)
Subscribing.
Opublikowany : 16/08/2024 9:45 pm
Opublikowany : 17/08/2024 12:11 pm
Steve Elves
(@steve-elves)
That seems to have done the trick.  There are still some minor artifacts in the print, but it is now usable.  Thank you! 😀
Opublikowany : 18/08/2024 5:54 am
1 ludzie polubili
Adrian
 Adrian
(@Adrian)
Gość
🤣 I was 10 seconds into looking at the forums for help with a print issue and this thread seemed like it was made for me. Love this community!!!
I'll try printing in structural or quality before asking about my own strange deformation
Opublikowany : 27/08/2024 6:59 am
