Strange deformation on one side of rectangular opening in vertical wall of a print
This seems to happen every time I print. I'm printing an enclosure case for a small IoT project; the case has some rectangular holes designed for display, access to SD card, etc. On one side of each cutout there is a strange ripple effect (see photo), which is not found on the opposite side of the hole. I'm assuming it's some sort of acceleration/deceleration effect, but I don't know for sure. This appears on the X-axis sides of the print; I've tested the tension of the X belt and it seems OK. Anything else I should try to diagnose this?
Best Answer by Diem:
You are using a SPEED profile which trades quality for time ... try using a STRUCTURAL or QUALITY profile and even a non Input Shaper printer profile.
RE: Strange deformation on one side of rectangular opening in vertical wall of a print
Files > Save Project as
Here it is...
Thanks! I hope you find something.
Subscribing.
That seems to have done the trick. There are still some minor artifacts in the print, but it is now usable. Thank you! 😀
🤣 I was 10 seconds into looking at the forums for help with a print issue and this thread seemed like it was made for me. Love this community!!!
I'll try printing in structural or quality before asking about my own strange deformation
