.stl file causes toolhead to drag on PLA on bed
eager
(@eager)
I've got an .stl file which is causing the MK4 Prusa toolhead to drag on the PLA that it's laid down on the bed. I held down the LED dial for 3 seconds and the Z chart appeared. I changed that Z setting to 0.43mm but the toolhead still drags. I watched a YT video which suggested in the Prusa Slicer (I have the 2.9.4) under the Printers (tab) you can then open the General (tab) and there is a Z offset that's set to 0 mm.  To prevent further nozzle dragging would it be advisable to change the Z offset there? To what number would you advise I change to? Thank you.
Opublikowany : 29/11/2025 5:53 pm
It would make sense to check the .stl - does it have a warning triangle next to it in the slicer list?
Opublikowany : 29/11/2025 8:14 pm
