Snug support failing almost every time
I'm creating a joint for my son's base. I've managed to print 3 of them when experimenting, but the having a problem right now.
I print on MK4IS, Prusament PTEG (freshly opened).
Supports necessary to print the tube:
The result:
The supports lines are very thin and often then change shape and not stick to the base, they create clogs, and it happened 3 times that it blocked the movement of the printing head, causing a layer shift. It made me to check all screws and tighten the belts.
I've even replaced the nozzle, because I've thought it's a problem with it. Indeed, the new nozzle seems to work better, but the old one was doing really good in general.
I would like to learn how to generate those supports so they're printable.
The organic supports (which i've not tried to print):
I don't like those huge branches, can i make it to just generate a support inside those holes and those tall branches?
RE: Snug support failing almost every time
What are your settings? Can you upload a 3mf project file? That way we can see your actual settings and make recommendations based on data and not assumptions. For reason unknown to mankind, 3mf projects need to be zip compressed before you can upload them here. Use your operating system's compress file command to compress the 3mf file, then use the "Attach file" button below the post editor to upload it. There's nothing in your model that makes me think you shouldn't be able to get proper supports.
Yes to please upload a zipped project file. Personally though I would orientate that part something like this -
but angled suitably for the 3 tubes. That way there would be minimal support and it would just be on the outside bottom. Wouldn't need to extend it much at all. The small holes in the sides shouldn't need any support at all though, even in the orientation that you have.
I’ve printed on default settings. Unfortunately I haven’t saved the 3mf.
Thanks for suggestion on orientation. I didn’t consider it but sounds like a great idea. I’ll play around with it.
I’ve solved the problem by changing the support angle to 45 degrees. It prints fine.
I’ll upload the images later.
thank you for sharing this amazing information.
I printed a similar part for square aluminum tubing - I found the supports, even though they "worked", caused the inside surface to be so rough it required a lot of filing to fit the tubing properly.
I ended up re-printing it, and used this orientation. All the supports were painted on, solely so that the piece would have sufficient adhesion to the bed. Printed beautifully!
I also really like the "reinforcing strut" idea that Diem mentioned - if that fits the application it's the way to go.
You may know this already, but keep in mind that the support angles in the slicer equate to the set angle subtracted from 90 degrees. So if your printer can handle 60 degree overhangs (which can be done on the Mk4S) , you'd set the overhang threshold to 30 (not 60). Likewise, if you're thinking that your printer can do 60 degree overhangs, and set 60 as your threshold, it will actually be providing supports all the way down to a 30 degree overhang angle, which is completely unnecessary in most cases. Setting this properly will further reduce the amount of support needed, and decrease surface irregularity from the supports. I mention this because all of the printer discussion/review videos discuss overhang angles in reference to a vertical axis ("This printer can handle 70 degree overhangs" etc.). I suppose there may a good reason why slicing software sets their overhang angles in relation to the horizontal instead of the more intuitive vertical, but it's an easy trip up point if you are not aware of it. Of course it is well documented in the prusa slicer documentation with excellent example images, but like many others, I was printing long before reading any documentation. 😊
-J
