Second Layer issues
Eric the Read
(@eric-the-read)
Miembro
Second Layer issues
I was printing... well, I forget what, now, but in any event, my nextruder started making the most horrible noise that sounded like a car trying to start with a dead battery. I opened up the idler, and there was no filament in it, but the filament wouldn't come out of the extruder. Eventually I was able to pull it out, but afterwards, I've been unable to complete a print. The first layer comes out perfectly, but the second is a completely splotchy mess. I've tried this with two different nozzles (0.6mm, then 0.4mm), and two different filaments (both PLA), and the pattern is exactly the same in either one:
Perfect first layer, splotchy and inconsistent second layer
My best guess is that something is restricting the volumetric flow, so that when the printer speeds up for the second layer, the extruder isn't keeping up, but I can't figure out what that might be at this point. It's not the nozzle, I don't _think_ it's the extruder. I did remove the planetary gears and clean and return them (with the PG alignment tool) to their housing, but nothing seems to work.
I'm perfectly willing to accept that I broke something, but for the life of me, I can't figure out what to replace.
Respondido : 21/02/2026 4:03 pm
I think you will be best served by taking this to Prusa Support via chat - you will need your machine's serial number.
Respondido : 22/02/2026 5:31 pm
1 les gusta
