Rough layer lines near corner
Any idea what could be causing the rough layer lines before this corner? The G-code Viewer screenshot shows where in the nozzle (0.4 mm) movement it's happening (the X and Y on the print itself doesn't match the printer axes, so ignore that). The lines feel very rough to the touch in comparison to the other corners. The other corner areas, both internal and external corners, look and feel smooth. There's no PrusaSlicer project to share because this was gcode taken from this input shaping calibration print. This issue happens with prints I slice myself as well, so it must be something wrong with the printer itself.
Dieses Thema wurde geändert Vor 11 months 2 mal von chrischin
Veröffentlicht : 01/06/2025 12:11 am
