Reflective PETG filaments?
Lemrik72
(@lemrik72)
I'm looking for PETG filament that has the same kind of reflective properties as what you see on safety vests, bicycle reflectors, street signs, etc.  Does such a thing exist?
Thanks!
Veröffentlicht : 11/01/2025 9:21 pm
JP Guitars
(@jp-guitars)
RE: Reflective PETG filaments?
You can get this sort of thing:
https://www.amazon.co.uk/ZIRO-Printer-Filament-Dimensional-Accuracy/dp/B01H3II7JW/ref=asc_df_B01H3II7JW?
No idea if it is any good but it is a good place to start. There are other colours as well
Veröffentlicht : 11/01/2025 9:34 pm
Lemrik72
(@lemrik72)
That's more of a fluorescent filament, it seems, as it requires blue or UV light to hit it to  make it fluoresce.  I am looking more for something that works like a bike reflector, as I want to print a new address plate or numbers for my mailbox so that it would be visible at night (my street has no lighting) to emergency vehicles, or just passing traffic.
Veröffentlicht : 11/01/2025 9:50 pm
JP Guitars
(@jp-guitars)
If you want reflective then no you will not be able to print it. Bike reflectors work by having a mirrored and shaped surface under a coloured transparent cover. Light comes in, bounces around and is then returned (roughly) to source. Have a look at one up close and you will normally see the prism shaped indents in the reflective surface under the clear red. The ultra bright stripes on high viz work similarly but using clear spherical reflectors.
Florescent should work like a high viz jacket and should glow when hit by a cars head lamps, particularly modern vehicles with halogen, HID or LED lights
Veröffentlicht : 11/01/2025 10:00 pm
JP Guitars
(@jp-guitars)
I would just buy something like this:
https://www.amazon.co.uk/Reflective-Stickers-Numbers-Adhesive-Wheelie/dp/B0CTQ45ZGK/
Veröffentlicht : 11/01/2025 10:04 pm
TeamD3dp
(@teamd3dp)
I agree with the above.  The prismatic reflective tape is so good, it's shocking.  Anything else would be so much less reflective that it would be disappointing. Plus,  its adhesive is very strong and the tape is durable.  If you want raised letters, you could simply apply the tape to the3d printed letters and then carefully trim around the edges.  I've used it on bicycle wheels for safer nighttime riding and it holds up very well.
You get what you pay for.  The 1"x50' rolls of "outdoor reflective tape" available at ULINE are $30.  That's the stuff I use on  bike wheels.
-J
Veröffentlicht : 12/01/2025 3:06 pm
Lemrik72
(@lemrik72)
I'd mostly want to print out a plate with reflective material (or cover it with reflective tape) then affix non-reflective printed black numbers on it.
Veröffentlicht : 12/01/2025 7:40 pm
Sembazuru
(@sembazuru)
Most of those retroreflective tapes are made with tiny glass spheres embedded in the tape. The tiny glass spheres are what create the retroreflective properties. I don't know of a filament that has the glass spheres. I also don't know the ideal size of the spheres, for all I know they are too large for the standard 3D printing nozzle.
See my (limited) designs on:
Veröffentlicht : 25/01/2025 8:18 pm
Sembazuru
(@sembazuru)
Posted by: @sembazuru
I should have searched the web before responding. There is a filament that has these properties. Search for "Reflect-o-Lay" filament. It seems to have spotty availability and is very expensive (on Matterhackers store it is out of stock and has a price of $63USD for only a quarter kilo, that comes to $252USD per kilo...).
On one of the store listings I found this YT video that claims the retroreflective filament is semi-flexible, sewable, and has a 2016 patent. I haven't looked at the patent to know what part of the filament is patented, but maybe just the existence of the patent is keeping regular filament manufacturers from making their own version?
Veröffentlicht : 25/01/2025 8:31 pm
Lemrik72
(@lemrik72)
I had seen that before asking.  It's PLA, not PETG, so I don't think it would hold up well long term outside.  I was also very off-put by the price.
Veröffentlicht : 26/01/2025 2:11 am
Sembazuru
(@sembazuru)
Posted by: @lemrik72
It's a flexible PLA, not sure what special sauce they added to make it flexible. (I have some MatterHackers flexible PLA, again I don't know what the special sauce is so I don't know if it is the same and I haven't tried it outside.)
I think the price is because the inventor can only make small batches so it is a boutique filament with a boutique price to match. Also, since it was released back in 2016 I don't know if it is still being manufactured so the price might also be because of limited NOS (New-Old Stock) supply. I don't know if the patent is for putting the glass beads into any thermoplastic for 3D printing, or if is putting the glass beads into the specific matrix material he is using. I haven't bothered to look into the patent. I don't have a relationship with any filament manufacturer strong enough to suggest new products. (The closest is some of the PrintedSolid guys recognize my face, but I don't know if they remember my name...)
Veröffentlicht : 28/01/2025 12:56 am
