Prusament PETG Signal White
I have a problem specifically with Prusament PETG Signal White filament and how to tune settings for it, with other PETG color filaments I get pretty good results with standard profile settings.
Prusament PETG Signal White is freshly delivered from Prusa, so there is no moisture case. I noticed that a substantial amount of filament built around nozzle during the print and from time to time it felt off from the nozzle causing blob and as a result damaged print or cause layer shifting (as IS profiles haven't got crash detections)
I've tried decreasing the filament nozzle print temperature, but it has caused constant filament stuck errors. Please advise what settings I must play with to reduce filament buildup around the nozzle.
Postato : 04/11/2024 7:02 pm
