Need assistance printing MMU3 Finda part, overhangs are bad
jbroggio
(@jbroggio)
Hello all,
I am printing out the parts for my MMU3 upgrade. So far so good, except I can't figure out how to get the finda perfectly printed - most of it looks great, but there are 2 parts where the overhang looks terrible.
I have a stock Mk4, am using the included prusament petg that came with the MMU3 upgrade kit, am printing on the textured PEI sheet, .2, 20% grid infill.  My first layer is 10mm second first layer (the first layer is great). The part is the R4 finda :
https://www.printables.com/model/531604-mmu3-printable-parts/files#preview.file.qIFQT
I have circled where I am having issues.
On attempt 1, I printed it on the sheet, no supports or anything. The part is fine except for those two overhangs.
https://imgur.com/4aXlgQt
On attempt 2, I printed on the sheet and turned on supports only for enforcers, and then painted supports onto the overhangs. The results were arguably worse.
https://imgur.com/bJ6dGdv
Any suggestions?
Best Answer by jbroggio:
I finally just opened the part in Rhino, added my own supports, and then printed it no problems first try.
https://www.printables.com/model/1354562-mmu3-r4-custom-supports-for-selector-part-overhang
I posted it if anyone else has the same issue. At least part of my problem (probably) is my printer is temporarily out on a desk in the open while I install the MMU3, normally it lives in an enclosure.
Este debate ha sido modificado el hace 10 months por jbroggio
Respondido : 06/07/2025 7:20 pm
LarGriff
(@largriff)
RE: Need assistance printing MMU3 Finda part, overhangs are bad
It would help if we could evaluate the .3mf file.  Create a .zip copy and upload it here.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Respondido : 07/07/2025 2:05 pm
jbroggio
(@jbroggio)
ok, I have attached the 3mf (zipping it only saved 4kb so didn't bother with that).
Respondido : 07/07/2025 10:13 pm
Chris Hill
(@chris-hill)
The forum will silently drop 3mf files - zipping them is the only way to get around that.
Respondido : 07/07/2025 10:52 pm
jbroggio
(@jbroggio)
whoops, good to know, thank you. I've attached a zipped 3mf.
Respondido : 07/07/2025 11:00 pm
jbroggio
(@jbroggio)
I tried painting organic supports onto those parts and the same thing happened, albeit slightly less badly.
This is literally the last part I need to start building my MMU3 so it would be terrific to figure this out if anyone has any advice.
Respondido : 09/07/2025 12:21 am
jbroggio
(@jbroggio)
Respondido : 13/07/2025 11:52 pm
Chris Hill
(@chris-hill)
Glad you got it sorted, but this is rather strange - that overhang shouldn't be difficult to print normally at 0.2mm layer height.  Is your part cooling fan working ok?  Perhaps you could rotate the part on the bed so that the overhangs are facing directly into the part cooling fan's output (e.g. 90 degrees anticlockwise from the orientation in your 3mf file)
Respondido : 14/07/2025 12:24 am
