RE: How do I get smooth sides to this ?
What you're seeing is that Rhino, on exporting it to a format for printing, is approximating those curves with straight lines. While 3D printing with true curves is indeed possible, Rhino doesn't export gcode that does so; instead, you're presumably exporting to STL or OBJ, which reduces curved surfaces to mesh.
If you want smoother curves, you need to export at a higher resolution. I don't work with Rhino so I can't give you details there, but if you search for 'Rhino export stl', you'll find plenty of tutorials showing how to adjust that resolution.
Postato : 28/07/2025 6:14 pm
Topic starter
answered:
Thanks Matthew...I will look into this further.
Postato : 29/07/2025 9:58 am
