Getting nowhere with Prusament PETG
teabot
(@teabot)
I am able to get some nice prints with Prusament PLA, but I am having a nightmare with Prusament PETG. First layer is always fine, but the second layer always catches on the nozzle. I thought it maybe moisture absorption in the filament, but it happens just the same with filament fresh out of a sealed packet. PETG Used to work fine when a pre-upgraded MK3S+ with the default configs. I've tried lowering nozzle temps, speeds, extrusion multiplier, but nothing seems to do the trick. I'd be grateful for any suggested that might help.
Opublikowany : 25/11/2025 6:26 pm
teabot
(@teabot)
RE: Getting nowhere with Prusament PETG
After digging deeper I have found the main factor behind this issue. I had swapped out the HF nozzle for a regular nozzle, but have not switched the profile. I now can get beyond the second layer. But now I have a new problem:
When printing a rectilinear infill, I hear a large amount of 'ratcheting' as the nozzle rides across the support veins. This initially creates a very small build-up of filament on the nozzle, but at around 5mm, begins to knock off the previously extruded infill material from the print. My print is large, but has a brim and shows no obvious signs of warping or separation from the build plate.
I miss z-adjust 🙁
Opublikowany : 26/11/2025 10:02 am
Bruce Labitt
(@bruce-labitt)
Don't assume that Prusament PETG is dry from the factory.  Mine wasn't.  (Bought two rolls of it.  Both were not dry.)  It hissed and popped while printing, and created a mess.  Yes, the package was both sealed and vacuum tight, but it was the soggiest filament I have ever experienced.  (Like it was stored underwater!)  Unfortunately, it was my first PETG that I had ever tried.  I got help from this forum.  What fixed the problem was 24 hours of drying at 55C (preferably 65C) and storing in a tight vacuum bag with over 3 ounces of desiccant.  These tiny silica gel packets do practically nothing!
After that, the default settings in PrusaSlicer were pretty good for Prusament PETG.
I did find with other brand PETG filaments, that I needed to adjust the extrusion multiplier to 94% and drop the temperature to 230C for the filament after the first layer.  I was getting blob build up during a print, just like you.  What really fixed the problem was reducing the extrusion multiplier.
So, I recommend you dry the filament!  It should cure your problems.  Then and only then, reduce the extrusion multiplier, if necessary.  Damp PETG does exactly what you have experienced.
If you get more serious, then consider a better dryer (with higher temperatures available).  I print directly from a PrintDry unit and have no issues with soggy filament anymore.
Opublikowany : 27/11/2025 5:11 pm
Which infill are you using?
Opublikowany : 27/11/2025 8:04 pm
Bruce Labitt
(@bruce-labitt)
Good point.  I don't use rectangular fill, I use gyroid, as I have fewer problems.
Opublikowany : 27/11/2025 8:08 pm
Bruce Labitt
(@bruce-labitt)
Here's a lovely print of wet Prusament PETG out of the new box.  It happens.  And when it happens to a person starting out, you just don't know what to make of it.  All default settings, because I didn't know what to change at the time.  (2022).  Dry it out, and things are a lot better.
Opublikowany : 27/11/2025 8:26 pm
Mac-N4MCC
(@mac-n4mcc)
If you are using PETG, I wouldn't use the high flow CHT nozzle.  I had a terrible time with that combination.
Extra HAM (and eggs some say) Radio - N4MCC
Opublikowany : 28/11/2025 2:20 am
1 ludzie polubili
JanLM
(@janlm)
Living near the Texas coast, I have discovered for successful printing with PETG, I need to first dry the new filament and keep it in a dry box or vacuum bag with desiccant.  I have had good luck with Sunlu, Jessie and Prusament and used both 4mm and 6mm High Flow Prusa brass nozzles.  But, I cannot print any PETG using the Prusa app and a Diamondback nozzle.
Opublikowany : 15/12/2025 7:07 pm
strjan
(@strjan)
I keep separate nozzles for Pla and Petg, for Petg nonHF.
I use cubic or gyroid infills, to not have the problem with bumping. (Cubic should be the default in my opinion).
There is Z adjustment: when print starts, long press the nob and you can adjust Z.
Opublikowany : 18/12/2025 10:18 am
Brian
(@brian-12)
It's nothing with the HF nozzle.  I print PETG with the HF nozzle without issue using the Prusament filament profile on a daily basis.  The only thing I ever change is that I lower the temp from 255 to 240 because I mainly use the structural profiles. The 255 is only needed with the speed profiles.
I also exclusively use rectalinear infill, it prints fast and it's nearly as strong as other infills like gyroid without all that crazy unnecessary extruder movement.  It's also one of the only infills you can use above 90% when you need to.
Opublikowany : 18/12/2025 1:46 pm
