Faulty Top Layer
Hi all,
for wuite s while Im trying to get this design printed reproducible good. As visible in the picture, the top layer gets faulty towards the edges. The print is done with PETG. The fordt layer and all except the last 3 where clean.
At first i thought it is some kind of warping, but the piece is very solid attached to the plat and the plate is flat.
un the middle ofvthe piece the surface is without wrinkles. So i assume print speed is ok.
Environment was at 20 degrees with 25%Humidity.
bed temp 85, nozzle temp 235
The settings were taken from the original Fiberology Profile.
Any suggestions are morevzhan welcome
Respondido : 10/01/2025 12:43 pm
