Corner lifts and wrinkles
RanDomination14
(@randomination14)
I have only been 3d printing for a few months now since I've gotten my first 3d printer, but occasionally on larger surface area prints, I get bending like this and it wrinkles up.
I thought it was poor bed adhesion in some areas after printing for a while on the smooth sheet, but even with cleaning it properly I would still get this, and its now happening on the new textured print sheet I just barely got that has no prints on it at all.
Only used PLA filament, different brands, different infill settings, and still no luck at a permanent solution to this.
Best Answer by Diem:
This is warping due to thermal contraction as the extrusions cool.  It is pulling the corners from the print sheet; in extreme cases it may even lift the sheet away from the magnets.
Protect the printer from drafts (including AC outlets.)
Use a brim and perhaps 'Helper Discs' - Prusa's version of 'Mouse Ears' which are easier to look up.
Use an infill pattern that does not stack long, straight, extrusions on top of each other.
Consider introducing cuts or grooves in surfaces/perimeters that might generate the greatest stress to break up the forces.  Like this:
In extreme cases consider annealing the part post-printing.
Postato : 28/10/2025 10:56 pm
Postato : 29/10/2025 4:00 am
RE: Corner lifts and wrinkles
Warping of large parts is a fact of life in 3D printing. Diem gave you a good list of things you can try. Often a brim will solve the issue but not always. Another option (with or without brim) is to use a thin layer of Layerneer or Magigoo. Those as both as a release agent when the model/sheet cool down but also help with adhesion during the print. Of course you can combine the suggested "solutions".
Postato : 30/10/2025 12:12 pm
RanDomination14
(@randomination14)
Thank you, this has been very helpful.
Postato : 16/11/2025 5:26 am
