Color Change extrudes a small piece of filament moving back to the print.
REB
 REB
(@reb-3)
When I insert a color change at the end of the filament change after its purged and I press yes the color is correct it extrudes a small piece as it moves back to the print.  I'm using the default 0.20 speed @MK4S HF0.4 print profile.  I tried turning the wipe tower off in the multiple extruders setting even though I have a single extruder with no change.  Its not oozing out, it extrudes it as it starts moving back to position.
Best Answer by REB:
Thanks, I found some older threads and apparently this has been an issue for awhile and nothing can really be done about it.  This seems to be by design in the firmware.  I personally don't like it,
Publié : 07/12/2024 7:16 pm
1 personnes ont aimé
RE: Color Change extrudes a small piece of filament moving back to the print.
I tend to add a tiny cube to the print and make sure in the preview that the slicer fills it in first on color changes. I found this to be the best way to avoid those "droppings"
Publié : 08/12/2024 11:07 am
2 personnes ont aimé
RNeese
(@rneese)
I have the same issue.  I just get ready for it to drop and grab it before the print head moves to print.  Like you said, this is not an oozing situation, it is being ejected by the print head.
Just upgraded to MK4S from an MK4, which had the same issue.  Using PrusaSlicer 2.8.1.
Publié : 13/12/2024 9:19 pm
Brian
(@brian-12)
I put my brass brush underneath before I hit the button.  It's always done this, even on the XL and mk3's after a color change or running out of filament.  I believe it does it to make sure you don't have any missed extrusion on your print.
I have had happen where I paused a print, and the nozzle oozed while paused.  That oozing makes it so that there's an empty spot insude the nozzle.  When I hit resume there ends up with a very small section with no extrusion on the part as the nozzle has to fill back up before plastic is extruded.
This is why if I need to pause a print I make sure to do it while it's printing infill so the mixed extrusion won't be seen.
Publié : 14/12/2024 1:35 am
RNeese
(@rneese)
Posted by: @brian-12
Using the brass brush makes more sense than burning my fingers grabbing hot filament.  DOH!
I still see no reason for the extruder to push out more filament.  It had just done a purge.  And yes, sometimes there is still a small bit dangling from the nozzle after the purge, depending on the filament (I find the higher the the nozzle temperature the more likely there will be a "dangler").
I wonder if they are doing a retraction after the purge and then pushing the filament back in when resuming the print?  If that is the case, I wonder if some custom G-Code could be added to move the head to a waste area and deposit the extruded bit before resuming the print?
I am going to get the MMU soon, and I wonder if this is still an issue with the MMU?
Ce message a été modifié il y a 1 year par RNeese
Publié : 14/12/2024 11:25 am
This is not a issue with the MMU
Publié : 14/12/2024 11:33 am
REB
 REB
(@reb-3)
Publié : 15/12/2024 12:26 am
RNeese
(@rneese)
Posted by: @joantabb
Thank you.  Good to know.  I know what I am getting for Christmas. 🙂
Publié : 15/12/2024 11:48 am
Brian
(@brian-12)
Posted by: @reb-3
I believe it to make sure there is no blank extrusions on your print.  Like I mentioned earlier depending on how long the nozzle sits before you resume printing you could end up with a spot with no extrusion from oozing
By having this in the software it does a quick small purge immediately before resummoning resuming printing.
Publié : 15/12/2024 5:38 pm
RNeese
(@rneese)
Brian, what you are saying makes sense.  It would be nice if they cleared the extruded part before resuming printing.  I get that it is tricky, but I would like that attempt made as opposed to just plopping that strand on the print.
Publié : 15/12/2024 7:00 pm
Razor
(@razor)
How do you make it print to the cube first?
Posted by: @foxrun3d
Mini+MK3S+XL 5 Tool
Publié : 16/12/2024 1:26 am
That is a tricky one. I wish I had a clear-cut recipe for it but at least in my hands it's been largely try and error. Changing the order of objects in the object list on the tight combined with rearranging objects and checking what gets printed first in the preview usually does the trick. I also have a stored template project that is set up correctly and use replace STL but when you have to add more objects to it it's back to try and error.
Publié : 16/12/2024 11:42 am
Sembazuru
(@sembazuru)
AFAIR this extra extrusion after the purge was explained by someone from Prusa to build back/stabilize the nozzle pressure. I use the last bit of purge extrusion to hold onto the pressure purge bit, and yank both off when the nozzle is about to touch the printed part.
See my (limited) designs on:
Publié : 31/12/2024 7:15 am
Roger
(@roger-10)
This would seem to be a bug in the firmware. They have put a lot of effort into enabling automatic color changes, even automatically detecting objects that look like they would benefit from color changes. This stray filament messes up the lettering *every time*. I hope they will take a look and adjust the retract / pre-pressurize parameters, since it seems we cannot correct it with existing parameters.
Publié : 14/02/2025 4:08 am
are you doing colour change by layer height? with extruded text?
Or Text in layer where more than one colour exists within the same layer?
Possible resolutions have been discussed on many occasions
 The post filament change nozzle prime has been a feature of slicing software for a very long time. I first addressed it in 2015
I have not found a way to cure the issue, but there are ways to minimise it!
Publié : 14/02/2025 10:07 am
Roger
(@roger-10)
I am using the text feature in PrusaSlicer using the cut option to have reverse embossed text. I am changing colors only between layers, not within a layer.
I know that there are a number of workarounds, and I successfully used the work around of having another tiny object on the bed and designating it to be the first touched by the new color. That worked fine. But that’s something one has to think of in advance in order to add the extra object.
I know that there are a number of workarounds, and I successfully used the workaround of having another Tony object on the bed and designating it to be the first touched by the new color. That worked fine. But that’s something one has to think of in advance in order to add the extra object.
I’m new to Prusa but I see from the discussion that this has been talked about for a while. The firmware does so many other things correctly to implement filament change that this seems like an oversight or bug. After the purge, it should not extrude any more filament. After clicking Yes to the color question, it should start correctly.
Publié : 14/02/2025 3:12 pm
