Z-Axis Calibration Error?
TwoWeims
(@twoweims)
My MK4S will sometimes think that the zero position is about halfway up to maximum.  When starting a print it will attempt to clean the nozzle in mid air and fail.  even if I run and pass the Z-axis calibration.  It reports that the zero Z position is here, about halfway up so I can't manually move it down any further.  I have to power off the printer and manually turn the Z motors past this spot and then it works OK.
Veröffentlicht : 01/04/2025 12:22 am
Kevin Rothi
(@kevin-rothi)
RE: Z-Axis Calibration Error?
It's a problem with the firmware. If you look at the release log for the last two builds it states that they've been trying (and failing) to fix it. I hope they get it right next time.
Veröffentlicht : 14/05/2025 3:00 pm
Kevin Rothi
(@kevin-rothi)
